Old 06-25-2017   #1
jeremy1375
jeremy1375's Avatar
1990 Eagle Talon Tsi AWD
***SOLD***
This isn't a POS. You won't be disappointed.
Runs, drives, and stops nice
6 bolt engine
RC 550 injectors
MHI EVO 3 16g turbo
EVO 3 exhaust manifold ported by Forced Performance
HKS 264 Cams (The receipts I received when I bought it showed HKS 272 cams, but the previous owner said they are 264)
HKS Adjustable cam gears
Aeromotive A1000 Adjustable fuel pressure regulator
Aeromotive fuel filter
Hallman In car boost controller
Indy Race Cores full size FMIC kit
HKS SSQV Blow off valve
Stainless J-Pipe
5 speed trans with less than 100 miles on Jacks Transmission bronze synchros. Shimmed to handle up to 400 ft/lbs
ACT 2600 Clutch
ACT street disc with less than 100 miles
Koyo throwout bearing less than 100 miles
Polyurethane engine/trans mounts
Fluidyne Radiator
FAL Twin radiator fan
Baer Big Brake kit
AGX Adjustable shocks
3" Turbo back stainless steel exhaust with cat and Magnaflow muffler
Sparco steering wheel
Thats about all I can think of right now. Many receipts included
The car is 27 years old and is not perfect
The EGT and Oil pessure gauges in the pod aren't connected
The windshield has a crack
Right front fender small dent - 2 small areas where paint is broke with light surface rust
Headlights are stuck up
Mileage is unknown as instrument cluster has been replaced
Left front tire rubs fender on hard right since car is lowered and has bigger than stock tires
The car needs a wash
ID:	16579   Click image for larger version
ID:	16580   Click image for larger version
ID:	16582   Click image for larger version
ID:	16583   Click image for larger version
