Thread: Project Lex
Old 08-09-2018   #1734
Re: Project Lex
Haven't had a ton of time on this car, but got some logs in today. I think we're already maxing out the flow of this new turbo. Here's a screen shot. You can see the boost pressure tapering off quite a bit (bright green line). But airflow is pretty steady & flat (aqua blue line). So we will still continue to up the boost but I think it'll only really make more boost early on, because at like 7000rpm and beyond I don't think it's going to flow much more actual air.
AEM shows a 710hp estimate. For comparison last year when I made 709hp @ DB, AEM estimated roughly 630hp. So a 70-80hp difference then, so if it's similar on the new setup that means I should be somewhere around 780ish or so. We will see, someday I'm going to get it on the dyno.
