Old 09-15-2022   #13
Re: I finally have another Mitsubishi...yes this is my old stealth
Whats the axle and driveshaft solution for fitting 4g63 stuff in one of these?
A few different options. Bolt on mounts exist. Depending if you are going automatic or manual you use one of the two rear ends available in the vr4 version.
Axles work with mitsubishi components. Generally a FWD pass axle and some cup swapping to make the driver side work (assuming you are starting with a TT chassis, another route is to go with a Non turbo chassis and its a bit easier as hubs clear, but then you're fwd).
AWD - move the yoke to match the dsm driveshaft. Or talk to DSS and have a shaft made to replace the front 2.
Of course I haven't finished all this, just research. Will post my results here as the drivetrain goes in. Confident it'll work out.
