Old 08-26-2004   #17
"The shifter linkage, shifter base, and shift levers on the tranny vary with years, you need to know how to make them work with each other if there from differnt years."
I guess no one reads what I say, also fwd and awd might be different. With it in 1st gear with the clutch pedal to the floor, and the car moves when you start it there is a dissengagment problem, ither master or slave cylenders or somthing got messed up on the install. The cluch fork should almost hit the end of the hole in the bellhousing when the cluch pedal is put to the floor. Also was the tranny taken apart/anything changed from when this tranny worked in another car?
