Old 09-08-2004   #26
So John I am having the same problem you were having with the pedal on the floor and there being about 2" of freeplay before there is any pressure. I can get the clutch to fully disengage but it is right on the floor worse than it used to be.
I just replaced the master and slave cylinders, put in the 1/4" longer rod in the slave and the pedal adjustment is all the way out (I mean all the way there are no more threads!).
I am stuck. I bled the slave and did the master too but nothing makes it better. I think either my pedal assembly is junk or something else is wrong (air in the system even after bleeds??)
It feels exactly like it did before I replaced both cylinders and --- I pushed it the clutch in to get out of gear on the way to the cookout and it felt sloppy and freeplay maybe gained 1 inch. So something happened as I pushed it in that day 3 weeks ago.
Im stuck?? Any suggestions?
