Thread: Need Help!
Old 09-12-2004   #7
Originally posted by enasnitsi@Sep 12 2004, 07:51 PM
Oh I forgot to put the key in. I didn't know you were suppose to do that when you start the car. Yeah thanks for your great words of wisdom.
Does anyone know where the fuel pump relay is because I ran a jumper wire and then the pump works so it has to be something in the factory wiring making the relay not open. Any advice that will actually help me would be great.
Thanks
brandon was just starting at the beginning of the 'diagnosis' process, which is 'did you do the test right?'.
Anywho, the mpi relay is located underneath the factory radio, on the passanger side kick panel. Check for power going to it (ecu) and power leaving it (to the pump), there should be your answer as to what the problem is.
