Old 01-30-2005   #10
Re: Challenge Thread
Originally Posted by 92tsiawd84
You are also trying to bet on a car that is not running. You cannot back up anything yourself. Nobody gives a shit what happened in the past. I am sure James will bet you now if you want to go. His $2500 gst which he just got vs your dsm. You can add Craig to that invitation also. He is a better driver you know. The car makes no bit of difference.
Fine, I will smoke him in my winter beater.
The only thing I am changing on my car from last year is the intake manifold, TB and cams. Granted it didn't run all that long, but when it did it was very strong. Shane is going to be doing the full tune on it this year. I should be able to max out that turbo. The exhaust side is probably going to be the main restriction. Nash held 40psi with his and I have a bigger compressor cover, so hopefully I can hold 32psi to redline. That should get me in the area I want to be in for HP. I am not using a cometic this year, they are too tough.
