Old 05-31-2005   #32
LightningGSX
Hellbound
Re: This is what my rebuilt 6-bolt consists of
Originally Posted by slowbubblecar
You didn't use a 1g cas? Why wouldn't you just use a 1g cas. I have never heard of anyone swapping a 6 bolt in and using the 2g cam and crank sensors. Why did he need to modify the front case other than the bs elim?
The 2g crank trigger is much better than the 1g setup.In the 1gs, spark is triggered off the cam, and as the timing belt stretches at high RPMs, it throws off the calculated ignition advance.Spark triggered off the crank position sensor(as it is in 2gs) is a much more accurate way.
EDIT:I'm pretty sure its the timing belt thats causes the random misfire code as well
-Nulli Secundus-
