Closed Thread
Old 01-28-2006   #1
94talonawd
94talonawd's Avatar
3s mas in a 1g help
Has anyone ever used the 3s mas in thier 1g before? I had an earlier post about putting in the 3s mas in a 1g. I still didnt get any luck with the mas working. I checked my wires a dozen times already and I am 100% sure they are right. I then thought it was the mas that wasnt working, so I swapped the mas of off my brothers 3s and tried it on mines. It still didnt work, I had the same CEL as I did before. So then I put my 1g mas back on, and it worked like normal. Everyone says that the 3s mas is the same as the 2g dsm's, but it doesnt seem to be working in my car.
Any hints or help would be greatly appreciated.
SOLD
94 Talon AWD
Big 16G
SAFC-II
99 Civic D16 - EVO3 16G - Hondata S300 - Xenocron 4bar@21PSI - RC750cc's - Eagles/Vitara - Compcams
12.3@114, 1.81 60ft
-On it's way to 11's....
94talonawd is offline
Old 01-28-2006   #2
Re: 3s mas in a 1g help
I have never heard of using a 3S MAS on a 1G, only 2G MASs. Is a 3S MAS the same part # as a 2G MAS?
Jakey is offline
Old 01-28-2006   #3
blageo23
AWD4G64
blageo23's Avatar
Maybe this will help maybe it wont. But check this out. http://www.vfaq.com/mods/2GMAF-1G.html
blageo23 is offline
Old 01-30-2006   #4
94talonawd
94talonawd's Avatar
Yea, I wired everything correctly. I know for sure that it is the 3s mas that doesnt work. I have been doing some searching and have found that there hasnt been anyone that used a 3s mas before. I have also found that the part numbers are different. Correct me if I am wrong, but there are people that says the 3s mas will flow more than a 2g mas. If, supposedly, the 3s mas works and flows better, then there would be a lot of people using the 3s mas instead of the 2g. The only conclusion that I have come to is that the 3s mas doesnt work on a 1g, that is why no one uses the 3s mas on a 1g. I am going to go pick up a 2g mas today and I will be back on here to post what happened.
SOLD
94 Talon AWD
Big 16G
SAFC-II
12.3@114, 1.81 60ft
Old 01-30-2006   #5
In all my days of internet whoring, I have never read a statement like that. Not to start a flame war, but who told you a 3S MAS would work on your car?
Jakey is offline
Old 01-30-2006   #6
CDeutsch
CDeutsch's Avatar
He maybe confused with "count" instead of "flow". This web page eludes that the 3S MAS can "read" (before it starts flaking out) higher then a 2G, and I know I've read that the Evo reads higher then a 2G as well.
http://www.stealth316.com/2-mas_liter-per-hz.htm
06 Evo IX RS
99 Miata
CDeutsch is offline
Old 01-30-2006   #7
94talonawd
94talonawd's Avatar
I bought the 3s mas from Josh at LSE Performance and they had told me themself, over pm and in person, that a 3s mas will work in my 1g. I just picked up a 2g mas an hour ago. Im putting it on right now. I'll get back on here once I'm done.
SOLD
94 Talon AWD
Big 16G
SAFC-II
12.3@114, 1.81 60ft
Old 01-30-2006   #8
Shotgun!
Totenritt
Shotgun!'s Avatar
It's "common knowledge" that the 3S MAS is the same as the 2G. I guess that is wrong. You should still be able to get it to work.
Shotgun! is offline
Old 01-30-2006   #9
Just ran the part number, they are different part numbers. I know I've switched them around in applications, but they are different part numbers so maybe its not a "100%" item that you can switch in ALL applications.
Just bring the mas back and I'll give you the $45 back.
I know my mas out of my stealth is in a 2g right now ::shrugs::
niterydr is offline
Old 01-30-2006   #10
you should jump straight to a GM maf and translator unit. soo much better anyway.
FattyBoomBatty is offline
Old 02-26-2006   #11
thomyd
Drives: 1ga
is that p&p with no afc needed? or am i going to need to install a safc before i use the 3"gm and translator? just sold the ems and looking for a new(less expensive) way to go.
thomyd is offline
Old 02-26-2006   #12
Fucking search and don't whore up another persons thread. There are a million discussions on this topic all over the net. While your at it start using the shift key and typing so we can alteast understand what the hell you are talking about.
If you are in 2nd grade and are thinking about putting a GM MAF and Translator on your big wheel I will excuse you. Otherwise shape it up.
Closed.
TheBlizzard is offline
Old 01-31-2006   #13
94talonawd
94talonawd's Avatar
Ok. I got the 2g mas in my car. Works like a wonder! So now we all know that 3s mas doesnt work for 1g's.
SOLD
94 Talon AWD
Big 16G
SAFC-II
12.3@114, 1.81 60ft
Old 01-31-2006   #14
Hmm wierd, I've swapped them around on 2g dsm's before.
Oh, stop by the new shop, I'll have cash for you. Sorry about the inconvience.
Or if you want, we can give you a $45 credit, pm me with what you want.
niterydr is offline
Closed Thread
