Old 02-23-2006   #1
brently
looks like my balance shaft did some damage
pulled out my front balance shaft to install my eliminator kit, didnt really notice anything wrong untill i popped out the front bearing, then noticed that there wasnt a rear bearing!!... looked at the shaft, and it was all damaged from smacking around inside the block. This doesnt bother me that much, since Im not re-installing them, but it however, ob-long where the rear bearing is supposed to go.. You should be able to tell from the picture, that the rear bearing doesnt fit.
So now, what am I supposed to do? Ill be able to block off the front journal because luckly that bearing fits. But what about the rear? I tryed to take off the little access screw, and it wont budge. Any ideas? Thanks guys!
brently is offline   Reply With Quote
Old 02-23-2006   #2
acidrumz
Send a message via AIM to acidrumz
Re: looks like my balance shaft did some damage
nothing out of the ordinary for 4g63's blocks.
somehow you have to get that oil hole blocked.
you can and if you can, could weld the oil hole shut. tricky because of tight fit issues. another is you can tap and die the oil hole and bolt it up, but it can be a issue.
anyhow, figure out whats the best route to do.
gluck
later.
acidrumz is offline   Reply With Quote
Old 02-24-2006   #3
Drill and tap for plugs in the oil passages would be your only option, besides getting a good 4g63 core from someone. Welding on a cast iron block is a really bad idea.
Old 02-24-2006   #4
drill through the outside and fill it with JB weld.
Old 02-24-2006   #5
Drill the outter access plug out to a larger diameter, then tap the oil feed hole at the balance shaft bearing and plug it off, then tap the outter plug and plug it off.
Old 02-24-2006   #6
brently
hey thanks everyone... i guess ill be doing some drilling and tapping this weekend.
