Old 03-08-2006   #1
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
I need some input
Ok i finally got my car back from the shop (After 3 weeks) and going to be putting so mods in to it. It is a 98 GS-T. OK here the mods MBC, Boost gauge and air to fuel gauge, 3in turbo back exhaust (2.5-3" RRE Downpipe
Apexi N1 3" catback) These aren't real big mods..But here is my questions.
When i put my exhaust on will it get rid of the O2 sensor? If so will it throw a code to the check engine light? Because I know the downpipe will replace the cat.Then the other is if i put the MBC will this also throw a code too? Ok thanks Guys..
Also does anyone know where to get some tubing for the boost gauge to run?And where to find a T fitting? One last thing is there anyone here who can port a O2 housing for pretty cheap?
thanks i know this is alot but any input will help alot!
-Tyler
Old 03-09-2006   #2
Re: I need some input
A MBC will not cause a CEL. Putting on your exhaust and eliminating your cat will cause a CEL.
Old 03-09-2006   #3
Porting, i was looking too, i saw that JET does it so i will probably use him.
Boost gauge stuff from any hardware store, i changed to silicone hose instead of that shitty nylon crap. I'm doing the same stuff too this week!
Old 03-09-2006   #4
JET is a good guy, he'll give you a fair price on whatever you need. The Autometer nylon tubing is actually good to use. It won't buldge/collapse like rubber and silicone can giving you more accurate and quicker response.
Old 03-09-2006   #5
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
I guess when I put my boost guages in I always used copper tubing. That nylon stuff kinks and breaks too easily (especially if it's moved around while it's cold). As long as you do it right, you won't get any kinks in the lines and is WAY more accurate than any hose. Nylon tubing is about as accurate as the copper tubing though. Never had any leak issues with it either.
Old 03-09-2006   #6
98gstaherns
Where do you get the tubing and or piping? Also thanks for the input to my other questions..also if anyone is looking for some fun putting in gauges i will be this weekend..a buddy was gonna help but know he is going out of town so if anyone wants to help. that would be great! Plus i could throw you some cash!
Old 03-09-2006   #7
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Napa sells a tubing kit. Otherwise you can get it from the hardware store. But you would need to get the compression fittings as well. They come in the kit from Napa. The hardware store you'd have to get it separate. 1/8" copper tubing and I can't remember the wall thickness.
Some don't like using it, but I never had a problem with mine. If I wasn't busy this weekend, I'd come up and help out.
Old 03-09-2006   #8
I won't be around this weekend, but the following I will be. I could lend a hand if need be.
Old 03-09-2006   #9
98gstaherns
well if any time you guys can the would be great..i'm more of getting my hand drity work not this wiring in stuff and all of that..i work at a shop so i have a place to do it plus i can call napa and have them bring me parts for cheap!
