Closed Thread
Old 03-20-2006   #1
eclipseGSX108
eclipseGSX108's Avatar
Send a message via AIM to eclipseGSX108
I ran the car
Like the title says.. Went to the track Saturday.. it was the first day of the track.. Didn't even think I was going to run it on the way down there but when i got there i couldn't resist to see what my DSM could do.
Get registered in- 1 hour
Wait to pull up to line- 45 minutes
time to get down the track- 14.012
Yeah its horrible but the clutch was slipping terribly for some odd reason.. Like i said its been leaking oil so maybe it was the rear main seal leaking oil and getting the clutch a little wet. I had a horrible launch.. 2.119 60 foot. I'm sure it coulda ran better but i was letting off trying to get that clutch to catch.
I dunno it sucks but there are lots of problems with it right now.. Once we get it fixed and tuned i'm sure it will hit a 12 sooner or l8tr.
This is the only forum i'm actually going to post my time on since my brother told me not to run it down the track because it would dissapoint me.. I'll post up my timeslip once i get a scanner or find someone who has one.
Discuss....
eclipseGSX108 is offline
Old 03-20-2006   #2
Onefast99gsx
Re: I ran the car
A 14.01 down to a possible 12? Yeah you must of had some slippage or something
Onefast99gsx is offline
Old 03-20-2006   #3
eclipseGSX108
Re: I ran the car
true.. it sounds stupid.. but with the setup i have it should hit 12's easily.. I know i'm a bad driver but i'm sure i could improve that also
Plus either the turbo is bad or the valve guides are bad.. because its leaking oil bad and shooting blue smoke.
^^ we are checking that out today after i get outta school..
Old 03-20-2006   #4
Onefast99gsx
Re: I ran the car
Where you from that the tracks are open? Leaking oil is not something track officials would like to hear. Time to get the jackstands out.
Old 03-20-2006   #5
eclipseGSX108
Re: I ran the car
STL. Missouri.
Track officials didn't know it leaks oil.. it just shoots blue smoke.. I agree on the jackstands
Old 03-20-2006   #6
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: I ran the car
what are your mods? something must have been really off if you got 14s instead of the 12 mark.
ლ(ಠ益ಠლ)
awd-drifter is offline
Old 03-20-2006   #7
Black97civic
35mpg
Re: I ran the car
well, he said he cut a 2.1 60' time. 1.6's are do-able with practice, right??
That would bring him down to a 13.5 with a slipping clutch and blue smoke. I could see 12's coming out of that with some work.
Black97civic is offline
Old 03-20-2006   #8
Onefast99gsx
Re: I ran the car
Takes a hell of launch to get 1.6's. That's not to say it can't be done though.
Old 03-20-2006   #9
Black97civic
35mpg
Re: I ran the car
Well, even so, a 1.8 would still get him well on his way to getting through the 13's.
Old 03-20-2006   #10
eclipseGSX108
Re: I ran the car
I have a 20g, 660's, afc, Eprom. Frontmount, HKS cams 264/272, full 3-inch exhaust, and Feramic Clutch.
The setup that was put on my car was off of a different car that ran a 12.1.. So obviously something is wrong
Old 03-20-2006   #11
Shotgun!
Totenritt
Shotgun!'s Avatar
Re: I ran the car
Yell shall seekth out thy dyno, and it will be good.
Shotgun! is offline
Old 03-20-2006   #12
Re: I ran the car
And then there was light!
Kracka is offline
Old 03-20-2006   #13
NOT THE BLUE LAMPSHADE
ROFLCOPTER!!!
Re: I ran the car
Move towards the light my son!
NOT THE BLUE LAMPSHADE is offline
Old 03-20-2006   #14
Re: I ran the car
OUCH!
You need some tuning.
I went 14.1@94 2 times with an airfilter and mbc at 14psi and no cat.
OEM everything, 1993 tsi awd.
I've seen 20g powered cars go 11's.
Get that 60' down. 2.1' is a decent 60'.
For a fwd on street tires.
niterydr is offline
Old 03-20-2006   #15
eclipseGSX108
Re: I ran the car
i'll go to the light for 100 bucks since thats how much it is for some tuning. Nobody around here knows how to do a small street tune.
Again either the turbo or the cylinder head is bad.. Since it goes through about 1 quart every 50 miles. and shoots blue smoke.. and leaves tons of black soot
Old 03-20-2006   #16
Re: I ran the car
What psi where you running?
I had simular mods on my FWD and went 13.1@115mph (24psi@c16 though) - Nash went 11.22@122mph with his 20G@c16
94mph is the killer though that right there shows you're in need of alot of tuning. Bad launch aside you can typically get a close idea of power based on MPH. Repeat Close idea. NOT exact.
SlowWhite is offline
Old 03-20-2006   #17
eclipseGSX108
Re: I ran the car
Don't have a boost gauge.. the boost controller is set ALL the way out so whatever its set on i'm sure its not that much, at least for a 16g. This was pump gas also
Old 03-20-2006   #18
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: I ran the car
Wow... Sounds to me like you need more mods and to tune your car. Without knowing about anything your engine is doing... Its like working on your car with a blind fold on and not knowing whats wrong with it.
Get a logger... Get a boost gauge... Before you do any dyno tuning.
Originally Posted by shoutbox
EclipseGST is offline
Old 03-20-2006   #19
eclipseGSX108
Re: I ran the car
i used my bro's logger no knock deffinatly need to get a logger... but thats all i really was paying attention to..
Deffinatly need to get a boost gauge also though.
Old 03-20-2006   #20
Re: I ran the car
... at least for a 16g.
errr, what happened to the 20G? and weren't you the one talking about your brother putting a fresh motor in your car? What happened with that?
scheides is offline
Closed Thread
