Old 03-29-2006   #1
armthelaser
armthelaser's Avatar
Oil Leak
My laser is leaking oil. It is leaking from somewhere on the t-belt side. I can not figure out where it is coming from it is all over everything, from the ps pump all the way down to thethe oil pan. I just turned back up my boost to 15psi and that is when got worse. It was only damp before now it is dripping a little when I park. Has anyone else had a leak in that area that covered everything? Any help woul be great.
armthelaser is offline   Reply With Quote
Old 03-29-2006   #2
Shotgun!
Totenritt
Shotgun!'s Avatar
Re: Oil Leak
Is it coming from the crack in the oil filter housing's hard line?
Old 03-29-2006   #3
LingLing
AznKraut
LingLing's Avatar
Re: Oil Leak
I had a leak just like that. If you have the time, tools and patience, replace your oil pump gasket, valve cover gasket, and re-do the RTV on your oil pan. I had a leak just like that, ice minion and I did those, and my leaks stopped.
Also, is it getting on your timing belt?
Old 03-29-2006   #4
Capinoy123
Capinoy123's Avatar
Re: Oil Leak
When I first bought my car oil was all over the front case, so I took the time and pulled it off and replaced all the seals on the front case including the front case gasket, its allot of work but all worth it!
Old 03-29-2006   #5
armthelaser
Re: Oil Leak
Are you trying to tell me that you knew about this the whole time?!
Maybe next time I'll just call you or...learn not to buy cars from you!
Old 03-29-2006   #6
Shotgun!
Totenritt
Shotgun!'s Avatar
Re: Oil Leak
I told you about that. It was welded up years ago. I'm sure Jess told you stories of it leaking oil everywhere. Anyway, I was going to call you when I first posted in here. When is too late to call?
Old 03-29-2006   #7
armthelaser
Re: Oil Leak
3am is too late usually...
Old 03-29-2006   #8
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
Re: Oil Leak
is it coming out of your head gasket?
96 Gsx Awd is offline   Reply With Quote
