Old 03-26-2006   #1
biggy fuel systems
i'd like to know who runs what in terms of fuel systems. from pump to injector and everything inbetween if possible.
anyone run the bosch 044 pump? i've seen more than a few writeups on it and it seems pretty effective if you want to keep the setup simple (i.e. not use 2 intank pumps)
input on line sizing regarding the feed and return line would be cool as well. -8 from pump to rail, -6 return?
thx
Old 03-26-2006   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
carltalon
I run a 255 intank -6an stainless fuel line -6an inline fuel filter stock fuel rail with -6an fittings welded onto it FIC 850 injectors aremotive regulator and stock return line. Im planning on runnign dual intank 255's this year I'm hoping my -6an and stock returne can handle the flow if not I'll get -8an and use my -6an for my returne.
I was thinking about going with the bosh 044 but I have an extra 255 here so I'm going that rought. I think 1visiousgsx is running that pump and has a great write up on it.
11.35 @ 120mph
Old 03-26-2006   #3
Re: biggy fuel systems
oh, yup you're right. he has a writeup on his cardomain site. kewl!
dayum!
here's that same can getting eaten by a Q45 tb
Old 03-27-2006   #4
FUEL:
Bosch -044 fuel pump (330 lph @ 75 psi)
VPE big bore fuel rail
Earls -8 1-way check valve @ inlet to the fuel rail
FIC 1000cc Ball/Disc injectors
Aeromotive A1000-6 1:1 AFPR
Aeromotive 12301 fuel filter
-8 braided steel line from the screen pick-up to the fuel rail
-6 braided steel line from the fuel rail to the AFPR
-4 braided steel line from the AFPR to the return line
1G throttle body/2G TPS
Fuel pump re-wire w/10 gauge wire ยท
http://www.cardomain.com/ride/225656/2
Works well.
Old 03-27-2006   #5
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Fuel cell
-10AN line to pump
A1000 pump
-10AN line to fuel filter
-10AN line to rail
Stock rail with 1600cc injectors
-10AN line to FPR
A1000 AFPR
-6AN return line to fuel cell
Hopefully never have to upgrade again!
Here is a link to the rest of the pictures...
http://photobucket.com/albums/e21/Dragtalon/
Originally Posted by shoutbox
Old 03-27-2006   #6
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
1visiousgsx That Gsx is carzy!!!! Way to go man!! Sorry for off topic
Old 03-29-2006   #7
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Jake, you better not have to upgrade again.
good write up 1visiousgsx.
