Old 04-22-2006   #1
Survey Says!
Well I got my car torn apart this afternoon and was pretty happy with what I found, but a little perplexed. One of the tabs on the throw out bearing broke off! Very strange. It was a brand new Mitsu unit with maybe 1k miles on it and 10 launches. At least the clutch is good. I will stop by Brookdale on Mon and grab a new one.
The retainter on the clutch fork had jumped behind the TOB. Hopefully it will be good to go after that. I am not yanking the clutch apart, but that looks fine from the outside.
So, my car should be at the dyno day on Sunday!
Old 04-22-2006   #2
Re: Survey Says!
glad to hear that it is not anything to serious. I hope that does the trick for you.
Old 04-22-2006   #3
Re: Survey Says!
Excellent!
Old 04-22-2006   #4
Re: Survey Says!
Huh? There's no side-to-side stress on the TOB, how would a tab break off?
Old 04-23-2006   #5
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Re: Survey Says!
installation? Maybe it was cracked before the install and finally broke.
- Josh L.P.
Old 04-23-2006   #6
Re: Survey Says!
I know how to put a damn TOB on :P I have no idea what happened, it just must have been a bad TOB. It broke right at the base of the tab where it is bent. There weren't any marks on it or anything from hitting anything.
Old 04-23-2006   #7
Re: Survey Says!
Nice kill!
See ya sunday!
Old 04-23-2006   #8
LaunchHard
LaunchHard's Avatar
Re: Survey Says!
The same thing happened to my car. I don't how long the bearing had been in there, but one day I was driving, normaly, then i couldn't get into gear. Opened it up, one of the tabs was broken off.
Old 04-24-2006   #9
iceminion
iceminion's Avatar
Re: Survey Says!
I'm glad to hear that it was something simple, good luck....and please, for the love of god, post times lower then 12.5 ok? thats 14b territory!!!
Old 04-24-2006   #10
curt_gendron
curt_gendron's Avatar
Re: Survey Says!
Glad to hear that its an easy fix. Its been a long time since I've seen your DSM.
later,
Curt
Minnesota 3/S
Old 04-24-2006   #11
Re: Survey Says!
Hey, it was a 12.4@99!
I am now being sent out of town even earlier, so hopefully the car is going again tonight. I will only have one more day after this to work on it.
Old 04-26-2006   #12
Re: Survey Says!
Well I don't know what the fuck is up with it now. I replaced the TOB and that didn't fix it. I can slowly push in the clutch and the twin disk will start to rattle then I push it in further and it makes a god awful noise like a bad bearing. It only does it with the clutch pushed in. The fingers were sitting like normal with it apart and none of the disks looked fragged. I am wondering if maybe I welded one of the disks to the plate? It is a quartermaster twin disk for those that don't know.
My patience is growing thin, I don't have the time to work on this thing all the time.
Old 04-26-2006   #13
Re: Survey Says!
maybe you overextended the fingers. aren't you supposed to run a pedal-stop with the QM?
Old 04-26-2006   #14
Re: Survey Says!
Hmm. Do you have full throw on the clutch system? Does the fork look worn?
Old 04-26-2006   #15
Re: Survey Says!
Is this a clutch from Devo Tuning? If so, I'd suggest getting ahold of Vassil as he has been having a number of issues with his twin disc.
Old 04-26-2006   #16
Re: Survey Says!
Yes it is from Devo. I have never heard of using a clutch stop. The clutch fork is a new billet one. Engagement is right in the middle and I do not use an extended slave rod. When it is making the noise it will not fully disengage some of the time.
The clutch fork seems to be moving properly. The rattling (normal) happens 1/3 of the way down, like normal. Get to 1/2 way and that is when the screaching starts.
Old 04-27-2006   #17
Re: Survey Says!
I have no idea for your clutch, but a clutch pedal stop is sometimes needed with multi disk clutches.
Old 04-27-2006   #18
Pimpin Dsmstyle
Br0k3N
Re: Survey Says!
Do you have an old ACT layin around? You could always toss something like that in there so you can get er on the dyno I guess that might just be a huge waste of time, but it seems you have one main issue at hand and it could probably be fixed by switching to a 6 puck or something.
- Josh L.P.
Old 04-27-2006   #19
Nash
Nash's Avatar
Re: Survey Says!
Jet is on a plane right now so his car will not be going on the dyno.
Old 04-27-2006   #20
Jana
Mazda Bitch
Re: Survey Says!
What happened? I thought he wasn't leaving until Sunday afternoon??
