Old 05-04-2006   #1
RWD Talon conversion
Hey, just cruising around looking for more specs on 1g DSMs, and look what i found. http://www.eagletalon.net/ dunno if you guys seen this, but it looked pretty interesting. the guy made his 1g rwd conversion and a longitudinal 4g63 mounted...pretty interesting find. i know he isnt the only one, but this looks pretty decent.
Old 05-05-2006   #2
Shane55113
Now 20% less Racist
Shane55113's Avatar
Re: RWD Talon conversion
or you could modify the front axles so they have a bearing on them that allows them to spin freely but put no power to the front wheels
Old 05-05-2006   #3
Thor06
11 Seconds to Freedom
Thor06's Avatar
When (if) I finish my current Talon, I was thinking of getting another for a RWD drift project. I dont think its too hard, obviously you'd need to make new motor/tranny mounts, but I think you use a AWD car, leave the rear end, get a mighty max tranny and driveshaft and you're set.
Old 05-05-2006   #4
It's two NABR members building it up as a race car. It should go real good once it's done. It was out at the SO two years ago on a trailer.
Old 05-05-2006   #5
b35talon
Drives: 92 TSI AWD
Did it run? How'd it do? Or did they bring it just to show off?
b35talon is offline   Reply With Quote
Old 05-05-2006   #6
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Thats a great idea for doing RWD the wrong way. You should slap an unpainted body kit on the car while you're doing the RWD "conversion."
Old 05-05-2006   #7
NOT THE BLUE LAMPSHADE
ROFLCOPTER!!!
Yea I don't think modifying your axels is the best of ideas, even if there isn't going to be any power going to them.
Old 05-05-2006   #8
They just trailered the body and frame down to show. They now have most of it put together, there's a buttload of one-off fab work on that car. It's going to be sweet when it's done.
Steve
Old 05-05-2006   #9
rst95eclipse
Only to make the Transfer Case explode.
Old 05-05-2006   #10
ROFLCOPTER!!!
Boom!
Old 05-05-2006   #11
Don't forget to weld your center diff with this genious plan...
