Old 05-21-2006   #1
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
Which gaskets should i use??
Whats up everyone i am in the process of puting a 1g motor in my 2g. My questions is which head gasket to use becuase i am doing a 7bolt head and 6bolt block for now, untill i get my 6bolt head fixed up. But if i do that combo 7bolt head and 6bolt block which gasket set should i get a 6bolt or 7bolt? I appriciate the help i just couldent find it anywere.
Finally tuned and fully built, Takes a lot of time,patience and money!!
96 Gsx Awd is offline   Reply With Quote
Old 05-22-2006   #2
96 Gsx Awd
96 Gsx Awd's Avatar
Re: Which gaskets should i use??
I think i figured it out, i need a 6bolt bottom end and 7bolt top end, and the head gasket dont matter it fits on both generations. Is this correct?
Old 05-25-2006   #3
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
I think the coolant passages are different 6 bolt to 7 bolt.
- Josh L.P.
Old 05-25-2006   #4
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
They are both the same. We used a 6 bolt hg on a 6 bolt with a 2g head a long time ago to get rid of a car.
7/25/09
Old 05-25-2006   #5
96 Gsx Awd
96 Gsx Awd's Avatar
I had Slowboy Racing tell me what i had said, that was my source thanks
Old 06-06-2006   #6
acidrumz
Send a message via AIM to acidrumz
mitsu metal hg should be good for you. you can opt to use copper seal on the hg before installation.
acidrumz is offline   Reply With Quote
