Old 07-24-2006   #1
DSMLink used for non recirc...
Hey,
The intake pipe im getting unfortunatly doesnt have the recirc pipe on it. I have dsmlink. I heard there is a way to make it so that it doesnt need to recirc, Is this true? what adjustments would i have to make?
Old 07-24-2006   #2
94talonawd
94talonawd's Avatar
Re: DSMLink used for non recirc...
I think you need a GM Maf.
SOLD
94 Talon AWD
Big 16G
SAFC-II
99 Civic D16 - EVO3 16G - Hondata S300 - Xenocron 4bar@21PSI - RC750cc's - Eagles/Vitara - Compcams
12.3@114, 1.81 60ft
-On it's way to 11's....
Old 07-24-2006   #3
I read a reply to a thread on here that you need GM Maf or DSMlink...
Old 07-24-2006   #4
What you "need" is to have the BOV in the intake system before the MAF/MAS/whatever is counting your air. That way, when the BOV opens and air exits the system, the ECU doesn't know that air is missing because it was never counted. Hense, the use of a GM airflow sensor, because it is placed in the intercooler piping near the throttle body, past the BOV. Either that, or get a speed density setup and AEM EMS.
As far as DSMlink itself allowing you to vent your BOV without drivability issues, that's news to me. My explanation above pretty much rules out that DSMlink alone can not solve the common issues with venting your BOV with the stock airflow sensor, but there are plenty of people who do it anyway without any problems.
Old 07-24-2006   #5
Ill try it disconnecting the recirc hose tomorrow and see how the car reacts and log it.
Old 07-24-2006   #6
94talonawd
94talonawd's Avatar
It will probably feel like crap in between shifts, Your RPM will drop really fast and cause your car to jerk when you shift, unless you can shift really fast. =)
SOLD
94 Talon AWD
Big 16G
SAFC-II
12.3@114, 1.81 60ft
Old 07-24-2006   #7
Shane55113
Now 20% less Racist
Shane55113's Avatar
its a controlled boost leak, open atmosphere b.o.v. are not performance orientated on a draw through setup period.
Old 07-24-2006   #8
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
I vent my bov with dsmlink and have no problems at all in my 2g. It just makes it a little rich between shifts as it isn't getting as much air. My car runs perfectly fine without doing anything else.
7/25/09
