Old 08-17-2006   #1
Enes
Enes's Avatar
speed density?
Ok, some of you guys know about this, however i don't. Can anyone sum it up for me and why/how is it better to run that, and can the 2g's be converted to use that?
-E
Old 08-17-2006   #2
Re: speed density?
its just easier to install and make big power with. you only need two thigs really, an Air Intake Temp sensor and a Manifold Pressure sensor. you just need to make sure your map sensor has enough range for the boost levels you are expecting (3,4,5 bar, etc.) Real easy to install too, just tap some holes in the uicp, the elbow, or the intake mani and you are all good.
As oppossed to running Mafs, which are definetly a restriction on a big hp cars and kind of a pain in the ass to deal with in general. i sure hope dsmlink v3 supports a maf feature.
Old 08-17-2006   #3
Re: speed density?
I hope DSMLink V3 supports speed density.
Old 08-17-2006   #4
Re: speed density?
i am dumb
Old 08-18-2006   #5
Re: speed density?
http://www.ktarry.com/pub/techhtm/air_metering.htm
Old 08-18-2006   #6
Re: speed density?
The VPC was a speed density system and you normally run standalone systems like the AEM EMS in speed density mode.
MAF/MAS systems know how much air is actually going into the motor. They are very popular with car manufacturers, because if the motor degrades over time or there is some problem with one thing or another, then the ECU can compensate on it's own quite easy. When there is a boost leak on factory turbo car, they will run richer, which can save a motor. Also, they can compensate for mods done to the car quite well.
Speed density systems only know air pressure, air temp, and sometimes barometric pressure. So they don't compensate for changes in the motor from mods at all. If you do something that makes more power, you go lean. Most Hondas run a speed density system from the factory. When you do a few bolt-on mods to one of them, they usually run very lean under full throttle. And you can't go in with an SAFC and add fuel by going positive because the ECU will then think it is somehow seeing boost and throw the car into limp mode. The OEMs also like to put the air temp sensors in stupid spots that cause them to constantly be heatsoaked and reading way too high.
The best part about speed density on a DSM is that when you blow off an intercooler pipe, you can still drive the car like normal.
Old 08-19-2006   #7
Shane55113
Now 20% less Racist
Shane55113's Avatar
Re: speed density?
killer info, thanks
Old 08-20-2006   #8
Enes
Enes's Avatar
Re: speed density?
Well, i have maft runing right before throtle body, is there any benefit of going with Speed density over dmslink/maft setup?
