Old 09-01-2006   #1
MYTOYZ
Question 16 Turbo lag
Sorry, title should read 16G.
Another question for you guys...
I've been trying to use the 'Search' but cannot get it to work so I apologize if this has been covered before.
I have a Big 16G turbo and am not real impressed with the turbo lag. I can't get the boost to kick in until the tach swings by 5500 in 1st. By the time I've hit full boost it's time to shift. Is this normal for a 16G?
98 GSX 5sp
03 Z06 517rwhp/490rwtq
MYTOYZ is offline   Reply With Quote
Old 09-01-2006   #2
Re: 16 Turbo lag
No, you have a serious problem, you should be hitting full street boost around 3000 RPM's. Either your turbo has already walked out the door or you have a serious boost leak.
Old 09-01-2006   #3
MYTOYZ
Re: 16 Turbo lag
Should I be able to build boost by revving the engine in nuetral? If I stab the throttle from idle I cannot build any boost.
98 GSX 5sp
Old 09-01-2006   #4
Re: 16 Turbo lag
Thats normal, you will only build boost if the engine is under load (i.e. not free-revving).
Old 09-01-2006   #5
MYTOYZ
Re: 16 Turbo lag
OK, thanks guys.
98 GSX 5sp
Old 09-01-2006   #6
MYTOYZ
Re: 16 Turbo lag
I think I will buy a Boostpro leak tester. Anyone had any experience with those?
98 GSX 5sp
Old 09-01-2006   #7
Re: 16 Turbo lag
Generally no, you need a load on the engine to build boost. Do a boost leak test.
Old 09-01-2006   #8
Re: 16 Turbo lag
I would make one yourself it is cheap and easy. Just either do a search for how to make one or take the measurements of piping on your car and go to the local hardware. good luck.
Old 09-01-2006   #9
Elementality158
Elementality158's Avatar
Send a message via AIM to Elementality158
Re: 16 Turbo lag
They are so easy to make. Ill get a pic of mine.
Elementality158 is offline   Reply With Quote
Old 09-01-2006   #10
MYTOYZ
Re: 16 Turbo lag
That would be great, thanks.
98 GSX 5sp
Old 09-01-2006   #11
Re: 16 Turbo lag
boosk leak or f-ed turbo.
Old 09-01-2006   #12
MYTOYZ
Re: 16 Turbo lag
Fingers crossed it's just a boost leak. In the higher gears when it spools up it holds plenty of boost. I would have thought it would struggle under all circumstances with a leak but I guess I'll find out.
98 GSX 5sp
Old 09-01-2006   #13
CDeutsch
CDeutsch's Avatar
Re: 16 Turbo lag
Could be an exhaust leak (or the wastegate isn't closing and exhaust is escaping out it) if it's a spool issue.
06 Evo IX RS
99 Miata
Old 09-01-2006   #14
MYTOYZ
Re: 16 Turbo lag
Thanks, I will check out the wastegate too.
98 GSX 5sp
Old 09-01-2006   #15
94talonawd
94talonawd's Avatar
Re: 16 Turbo lag
Could be a boost leak.
But I highly doubt you will be able to build good boost at 3k in 1st gear.
How is the boost in 3rd gear?
SOLD
94 Talon AWD
Big 16G
SAFC-II
12.3@114, 1.81 60ft
-On it's way to 11's....
Old 09-01-2006   #16
MYTOYZ
Re: 16 Turbo lag
3rd - 5th is not too bad. It just feels like a slug in the first 2 gears.
My clutch issue is probably not helping since it chatters if I try to launch over about 1800 rpm so I am not laying into it until the clutch is fully released.
I used to have a 92 Laser RS AWD Turbo and it spooled alot quicker with the stock 14b, that's what I am comparing to.
98 GSX 5sp
Old 09-01-2006   #17
94talonawd
94talonawd's Avatar
Re: 16 Turbo lag
What are all of your mods?
If it is a boost leak like what some are saying, it would have to be extreme. And If the leak is that big, your car should sputter. Does it sputter under boost?
Check your manifold to see if it is cracked (Most likely it wont be cracked, unless you still have the stock 1g manifold). Also check the four bolts on top of the manifold that holds onto the turbo and make sure they are tight. If they are tight, check the metal gasket that lays in between the manifold and the turbo. My guess that there is a leak somewhere around there, causing air to escape and not spinning the turbine wheel like it should, and causing slow boost build.
I would also consider looking at the wastegate flapper to see if their is a crack on the housing (i highly doubt thier is a crack though, but just incase) causing air to go pass the wastegate and not spinning the turbine wheel like it should.
Check also to see that your wastegate is tight. Not moving freely. Make sure the wastegate flapper is closing all the way.
My .02 cents.
SOLD
94 Talon AWD
Big 16G
SAFC-II
12.3@114, 1.81 60ft
Old 09-03-2006   #18
MYTOYZ
Re: 16 Turbo lag
My .02 cents.
Mods are Big 16G turbo, Blitz BOV, 3" turbo back exhaust, S-AFCII, Greddy Electronic Boost Controller. I have not had the car long and am not sure if I have any fuel upgrade mods, I need to do a little research into the injectors.
Once the boost builds it does not sputter at all, the boost holds really well and the car pulls.
Thanks for all of your advice here. I will spend a night during the week investigating everything you guys have pointed out.
98 GSX 5sp
Old 09-03-2006   #19
94talonawd
94talonawd's Avatar
Re: 16 Turbo lag
I would probably look in to the electronic boost controller.
On my 3/s, I had the Blitz dual SBC and there was soo many settings on there to configure and it didnt work out properly. It was causing wierd boost settings and sputtering.
Look at the manual to see if the setting on the boost controller is set properly.
When I had took off the electronic boost controller on my 3/s and put on a manual one. It fied all my car problems.
I dont know if this is a factor involving your problem, but it was for me.
So I would just look into that too.
SOLD
94 Talon AWD
Big 16G
SAFC-II
12.3@114, 1.81 60ft
Old 09-01-2006   #20
Re: 16 Turbo lag
Check the wastegate actuator and see if the shaft going into the turbo didnt slide back making the flap not cover the eitire hole inside the turbo. I have seen this before but i dont know what turbo you have.
