Old 10-18-2006   #1
GUY
Question what to replace?
ok i have a 95' eclpise FWD with some small mods and i need to replace the clutch, i was wondering if anyone else had problems after they got a new clutch in that i should replace while the tranny's down? bushings, throw out bearing, clutch fork etc....
GUY is offline   Reply With Quote
Old 10-18-2006   #2
Re: what to replace?
Always replace the throw-out bearing with a Mitsu bearing when replacing the clutch. You should of course also machine the flywheel and replace the tranny fluid with a good performance fluid. Otherwise, replace anything else that looks worn.
Old 10-19-2006   #3
GUY
what kind of oil would you suggest with some wearing on the 3rd gear syncro?
Old 10-19-2006   #4
Shane55113
Now 20% less Racist
Shane55113's Avatar
amsoil syncromesh
Old 10-19-2006   #5
Redline MT-90/MTL blend.
Old 10-19-2006   #6
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
Send a message via AIM to gofastman
I would shim the pivot ball the clutch for moves on with a washer, raise it about 1mm, a lock washer works well.
make sure the clutch is properly adjusted, if it doesnt disengage fully it will place alot of extra where on your already shitty synchros, and make the tranny grind
-David C.
Originally Posted by bouncer07
If you know Mary Clifford, Ph,.D. Associate Professor of Criminal Justice in St. Cloud State University. Then your well aware of who she is.
gofastman is offline   Reply With Quote
