Old 12-01-2006   #1
sway bars
Well I've been thinking about getting lower sway bars for my 98 gsx. I have read that rear sway bars are very helpful, but are the fronts necessarily worth the money? like these bad boys are pricey and I was wondering if I should get the front and rears for like $300 or just the rears for like half that? And if anybody knows where I can get a cheaper set lemmy know!
Old 12-01-2006   #2
Re: sway bars
Get the front/rear set of RM bars, my friend put them on his '98 GSX and it was a huge improvement. Search around a bit, we had a huge swaybar thread just a few months ago.
Old 12-01-2006   #4
Re: sway bars
Thanks, I found that thread and I think I might just go with the rear sway bar for now. I'm in the process of getting all my fuel mods on and then I'll need a tune, so that'll cost a buck or two.
Old 12-01-2006   #5
Re: sway bars
Will I still need sway bar links if I get sway bars?
Old 12-01-2006   #6
rst95eclipse
Re: sway bars
Yes. Aftermarket sway bar kits do not come with end links. I've searched this issue since I had to cut my endlinks off. Let's just say that they cost a pretty penny. If you find a kit that does come with the endlinks.........please please please let me know of it.
Old 12-01-2006   #7
Re: sway bars
Well the thing is, my links are off right now because of some suspension work I did a while back. So will I have to buy a set of links and put them on as well as the sway bars themselves?
Old 12-01-2006   #8
rst95eclipse
Re: sway bars
I don't know how your sway bar is going to work unless you install the endlinks as well. If your question is if you need new end links - you shouldn't as long as you can still install them (torque them to specs).
My problem was that the metal was so corroded and fatigued when I put my 14mm open between the rubber caps and started to wrench off the nut - the area that the 14mm was on stripped.
Old 12-01-2006   #9
Re: sway bars
Aftermarket anti-swaybars are a great upgrade for even stock suspension DSM's. I am glad to see more and more DSMers finally getting into handling.
Old 12-01-2006   #10
rst95eclipse
Re: sway bars
I agree with you completely. But it's definately not the first suspension mod that one should do. After a lowering kit and strut bars, it would be my next choice. But I would buy up a brake kit before some sway bars.
Old 12-01-2006   #11
Re: sway bars
They have upper sway bars?
Old 12-01-2006   #12
Re: sway bars
Many people confuse sway bars with strut bars. Just trying to be specific
Old 12-01-2006   #13
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
Re: sway bars
owned!
-David C.
