Old 08-10-2007   #1
Tman1gtsi
idle
upon starting my 1g which hasn't ran in over 6 months, i found that it wont ldle, unless of course i give it gas, we set the afc as it should be, but even if we are off, shouldn't it idle, it also is almost out of gas becuase of when it died, what could it be???????
Old 08-10-2007   #2
Re: idle
maft? safc wiring? biss screw? you compensate for those injectors?
-A. Swift
Old 08-11-2007   #3
Tman1gtsi
Re: idle
ya did all of that, could it be that i have no o2 sensor hooked up yet
Old 08-11-2007   #4
Re: idle
If the battery was dead, it probably zeroed out all of your learned tables. It will relearn the idle settings, takes a few minutes. The o2 sensor not being there will default the ecu into the rich/cold start mode. And put gas in it too.
