Old 12-19-2006   #1
Buschur Borg-Warner Turbo kit
Looks like buschur is building a turbo kit out of the Schweitzer/Borg-Werner S200 turbo. Looks intriging, and the thing is supposed to flow around 57lbs/min!
http://forums.evolutionm.net/showthr...06#post3772506
Old 12-19-2006   #2
Re: Buschur Borg-Warner Turbo kit
Borg Warner/Schwitzer ftw, I've got an ancient semi-truck or earth mover turbo by schwitzer, I should toss it on a car sometime; I bet it would make some buku hp.
Old 12-19-2006   #3
WOw, pretty good deal for 2 grand i would say.
Old 12-19-2006   #4
v8klla
v8klla's Avatar
Our friend Bill, 4las90, has an S200 on his talon... Made 380ish or so with minimal mods... We're building a motor right now, then we'll see what it can really do!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 12-20-2006   #5
Looks like the S200 was a bust
http://forums.evolutionm.net/showthr...17#post3776017
360whp and 302 lb-ft @ 27psi ...lame!
Looks like he's gonna test a S300 though...65lbs/min I think....
Old 12-20-2006   #6
The S200 is only a 56mm compressor wheel. It's close in size to a Garrett 57-trim comp wheel, which is rated at about 49 lb/min. Those numbers are still a bit dissappointing for boost level and motor in that car. An S300 is very close in size to a 61mm Garrett turbo like the GT35R and PTE SC61
Old 12-20-2006   #7
Shane do you have any experience with these extended tip turbos?
Old 12-20-2006   #8
I don't have any experience with those turbos. Nick from SLS has been running them for years though. In general, when you increase the size of the exducer side of a compressor wheel, it makes it more efficient at higher boost levels, but doesn't increase the overall flow capabilites a lot.
Old 12-23-2006   #9
Who is Buschur working with on those kits, Bullseye?
Old 12-23-2006   #10
He hasn't said.
