Old 01-14-2007   #1
chickensoup
Grinding In Reverse?????????
well let me make something clear first , grinding is when u put it in a gear and it jus feels like its jus grinding up against something right??
well my car is grinding in reverse no other gears just reverse?
any help would be awesome
-Sam
chickensoup is offline   Reply With Quote
Old 01-14-2007   #2
Re: Grinding In Reverse?????????
Before I put my car in Reverse, I first shift it into 1st, and then into Reverse. Sometimes if I just go to throw it in Reverse, it will grind. But shifting to 1st, and then Reverse, seems to help a bit.
Old 01-14-2007   #3
chickensoup
ok thanks ill try that
Old 01-14-2007   #4
Make sure the clutch master cylinder is adjusted properly too. Also, replace that tranny fluid with some good Redline stuff, I'm pretty sure Chris just had stock stuff in there. Replace all your rubber shifter bushings too with some nice metal ones, it makes a huge difference in shifter/tranny feel.
Old 01-14-2007   #5
chickensoup
alright im gon do all this stuff next week its snowing ahha thanks
Old 01-14-2007   #6
With my Evo I pretty much can't get it into reverse without going into 3rd first. After that it goes right in.
Old 01-15-2007   #7
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Reverse isnt a synchro'd gear (straight cut) so there for if your input shaft is spinning it will grind. By putting the tranny in 1st/3rd/5th, it stops the input shaft.
Originally Posted by shoutbox
Old 01-15-2007   #8
chickensoup
alright thanks guys for all the info and yes it does work now putting it in 1st/3rd/5th then reverse thanks guys
