Old 02-17-2007   #1
v8klla
v8klla's Avatar
Huge Competition Clutch Sale, Starting @ 279.99!
As always, shipping is free in the continental USA!
Stage 2 $279.99
http://www.maperformance.com/store/p...6&cat=0&page=1
This assembly provides approximately 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life.
The 2100 Series kit includes a performance pressure plate, a high torque sprung disc with antiburst steel backed Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool.
*Don't let the part numbers fool you, this Stage 2 kit includes a 2700 lb pressure plate! It will hold as much if not more power than an ACT 2600!
Stage 3 $369.99
http://www.maperformance.com/store/p...cat=260&page=1
This segmented Carbon Kevlar material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. 500 mile break-in REQUIRED with this set-up.
The 2300 Series kit includes a performance pressure plate, a high torque sprung disc with segmented Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool.
Forged Lightweight Steel Flywheel $224.99
http://www.maperformance.com/store/p...cat=261&page=1
The ST flywheel is recommended for naturally aspiriated and/or street driven applications. This flywheel will work with ALL performance and stock clutch assemblies.
Qualities of the CCI Lightweight Steel Flywheel:
Preserves low end torque and drive ability
One piece ring gear for high durability
Weight varies from 11 lbs. to 14 lbs. depending on application
Well suited for Stage 1 and Stage 2 clutch kit applications
Stamped with 4140 plate with 2000 ton pressure at 1260 degrees
CNC machined and balanced to O.E. specifications
Reduced Mass = Increased Accleration
Meets and exceeds SFI 1.5
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 02-17-2007   #2
Re: Huge Competition Clutch Sale, Starting @ 279.99!
S2000 guys are having great success with Comp clutches.
Old 02-17-2007   #3
v8klla
v8klla's Avatar
Nice! I guess you know where to look when it comes time to upgrade
Chris
P: 763-545-3800
Old 02-17-2007   #4
That first one looks interesting. I currently have an X-Clutch, and I believe it also uses a 2700lb Pressure Plate, with a full faced organic disc. Looks like that first one would be similar to it.
