Old 02-17-2007   #1
Onefast99gsx
Question Engine Stand Question
Hi guys- I'm removing the motor out of the GSX this weekend. I want to put it up onto the engine stand once it's out. The front/lower bell housing bolt hole on the block has a guide pin in it. Do you normally have to remove this or how do you get around it? I tried lightly with a pliers and it started to knurl it so i backed off.
Thanks for any help...
Old 02-17-2007   #2
DBMajik
Re: Engine Stand Question
Well what I did was use the stock main bolts. I know for sure I used the two top tranny bolt holes. The other two I don't remember. Just try to find holes with the same thread pitch.
DBMajik is offline   Reply With Quote
Old 02-17-2007   #3
DBMajik
Actually, here's an old picture. You just thread the bolt into the hole you mentioned.
Old 02-17-2007   #4
The tranny dowel pin slides right into an engine stand arm.
Old 02-17-2007   #5
TwoTalons
Old & Grumpy
TwoTalons's Avatar
Drives: 1992 Eagle Talon TSi AWD
Bingo!
TwoTalons is offline   Reply With Quote
Old 02-18-2007   #6
Onefast99gsx
Thanks guys... I ended up having to ream out the engine stand post thing with a drill. It wouldn't have fit otherwise. This is a home-made stand that I borrowed.
