Old 04-12-2007   #1
Berda
Berda's Avatar
Send a message via AIM to Berda
Apexi AFC ?'s
Just got the afc in and am having a little trouble with it. I followed the vfaq procedure, and the afc does work. However, when i shut the car off and turn it back on, the settings are reset to factory defaults. When I bought the afc, it still had the previous owners tune on it. Do the afcs have batteries and memory to back up your tune? I could just hook up the power wire to a constant voltage ( i think its 12V) but then the afc would never shut off. Hope to get this figured out soon so I can get a tune.
Thanks,
Adam
'91 TSi AWD Stock - 161.7 AWHP! Sold :(
'99 Honda Accord EX Coupe V-6.
Berda is offline   Reply With Quote
Old 04-12-2007   #2
Re: Apexi AFC ?'s
It sounds like an install error, double check your install and it should save everything even if you unhook it from power.
Old 04-12-2007   #3
Re: Apexi AFC ?'s
Install error, check which wires you tapped for power and ground.
Old 04-16-2007   #4
Re: Apexi AFC ?'s
These things do go bad, too. I had one in my 2G that appeared to be working but wouldn't do anything. I even had someone else re-install it to no avail. How old is it? Is it an AFC or S-AFC? Might try another unit & see if it helps. Double check all of your wiring, solder every connection, if you can.
Old 04-16-2007   #5
Re: Apexi AFC ?'s
Everything since the 5-knob has been called a S-AFC. Since its loosing memory its either a blinky-blue or a S-AFC2.
Old 05-02-2007   #6
Berda
Berda's Avatar
Re: Apexi AFC ?'s
it is an safc 1 and i followed the vfaq install, and also double checked on several other pinout diagrams. It does save the settings every so often, which is very odd. I think the unit itself is bad. I'll call apexi and see if they can help.
