Old 04-19-2007   #1
rx_08
rx_08's Avatar
Trouble with my deck working!!!!!!!!
can anybody help me out?????????my deck just all of suddenly died when i was listening to it and it wont turn back on!!!!Does anyone know what could be wrong with my car?????????
rx_08 is offline   Reply With Quote
Old 04-19-2007   #2
tim
tim's Avatar
Re: Trouble with my deck working!!!!!!!!
I would start by checking the fuses. The one in the back of the deck and the one in your fuse panel. If they are good pull it out and make sure it still turns on when hooked up directly to a power and ground.
Old 04-19-2007   #3
rx_08
rx_08's Avatar
thanks man let me go try it out....
Old 04-19-2007   #4
rx_08
rx_08's Avatar
its still plugged in and still dont work....i checked the fuses and they were still good......
Old 04-19-2007   #5
tim
tim's Avatar
Do you have a volt meter? Check to see if it is getting power. If you have another deck you can swap in or another car you can try your deck in you could do that too.
If you cant do either of the above there isnt much more people can tell you here.
Old 04-20-2007   #6
polishmafia
Smells like cat poop
polishmafia's Avatar
did you try what tim suggested? using a direct power supply to the deck? if it doesnt turn on then, the deck is gone.
is anything else not turning on or malfunctioning? id just check the fuses to the a/c gauges, your cluster, etc.
Old 04-20-2007   #7
x-pride
x-pride's Avatar
Is your cigeretta lighter still working? Did you check the fuse on the radio and in the car?
Old 04-20-2007   #8
rx_08
rx_08's Avatar
yea i just noticed this morning that not just the deck is dead but my door locks are dead too.......
Old 04-21-2007   #9
x-pride
x-pride's Avatar
Make sure you find out what cause your car fuse to blow. If you find a blown fuse.
Old 04-24-2007   #10
92EvilTalon
3.1L v6 power...
92EvilTalon's Avatar
Pit Stop Challenge Champion!
Does the auto seat belts work still? If they quit too check your 80amp fuse. Its the big black one. If that blew there is your problem. But also check to see if a wire was crossed. Good luck.
Josh LaCroix
Old 04-24-2007   #11
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Check the deck ground wire. ground it to the frame.
Amsoil Dealer
