Old 02-08-2007   #1
Toms Project...
Ok so heres the synapsis (not sure on the word usage) of what im planning for my car, what the Goals for the build are, and what parts i have and will be ordering.
Table of Contents:
Chapter 1...... Planning is everything
Chapter 2...... Goals for the build
Chapter 3...... Status On Current parts and parts to be added
Chapter 4...... Estimated time when Eclipse will be ready
Appendix A.... Pictures
Chapter 1
Planning is Everything
When i was a wee lad... just kidding. The plan for the car is simple, a) Get it running, b) Keep it running and c) Make it as fast as possible in the budget i have.
This time around i am going to make sure i have completly happy with the setup before i start driving, meaning that everything that needs to be taken care of will be.
Before the synchro went out in second, the car had no speedo because in taking out and putting in the tranny 5 times in 2 months the 4th time it was taken out the speed sensor got caught on the motor mount and snapped.
The other issue i was having is that i didnt feel like the knock sensor was working properly due to the amount of knock i was reading on dsmlink. but also when i took everything apart i accidentally pulled the wire out of the knock sensor.... oops.
Chapter 2
Goals for the build
Goals are the same as when i first got this car. This car will be used as a daily driver/Race car for Drag Racing. I would like to see over 500 FWHP (not hamster power). I would like to be able to throw the slicks in the trunk and drive to the track, put down some good times and then pack it up and drive back home.
The main thing with this build is i am not going to leave anything to chance. I am going to make sure that all of the parts are in good shape, that everthing will work as intended and that i get the most out of each part i put on. From Brakes to a Wideband, as long as it takes this will be done correct.
Chapter 3
Status of Current Modifications and Parts to be added.
Engine:
RRE 6Bolt block
RRE Stage 2 Head
2G Pistons 8.5:1
HKS Valve Springs
Ferrea Valves
NGK BPR7 Spark Plugs
Forced Induction:
PTE T3/T4 50 Trim Turbo
Tial 38mm External Wastegate
Ported Exhaust Manifold
Front Mount Intercooler
Magnus Intake Manifold
Custom Piping 2.5 in made by me.
Greddy Type S BOV
RRE Upper IC Piping
Fuel Management:
DSMLink
Magnus Fuel Rail
Fuelab 525 FPR
3/S Fuel Pump + rewire
680cc Injectors
SS braided Lines From Mesa Hose
Wideband o2 Sensor (Coming soon)
Drivetrain:
Fidenza Flywheel
ACT 2100 Clutch
Transmission Race Built by Dogbox Racing with Phantom LSD
Southbend Clutch (Possibility)
Baer or AEM Big Brakes (coming soon)
Other Points of Interest:
2.5" Turbo Back Exhaust
Magnecore Race wires
Tokico Shocks and struts
Battery Relocation to the trunk.
New Knock sensor (Coming Soon)
New Speed Sensor (Coming Soon)
New Throttle body (coming soon)
Possibilities include:
GM 3Bar map sensor
Bigger Injectors
2g Front fenders, bumper and headlights
Chapter 4
Estimated time when this project will be complete.
When is a DSM ever truely complete. This project however i am giving a good guesstimate of 1 month. But I am not going to restrict myself with a time frame. I would rather take the time to do it right then do a half assed job which will just cause me to use more time under the hood.
In past projects i have been in a rush to get things done for some race or track or dyno day. So with that said we shall see how long this actually takes. I have a lot of decisions to make still with this build but we will take it one step at a time.
Appendix A:
Pictures
ID:	4967   Click image for larger version
ID:	4968   Click image for larger version
Old 02-08-2007   #2
Re: Toms Project...
Just got word back from Dogbox Racing. Here what is gonna happen to the tranny: (some quoted from website)
1-2 hub/sleeve
3-4 hub/sleeve
1st, 2nd, 3rd, and 4th gear
2nd gear double cone syncro
1st, 3rd, 4th, 5th, & reverse syncros
both tapered input shaft bearings
both tapered intermediate shaft bearings
both half shaft seals, input shaft seal, & output shaft seal
steel shift forks
Additional:
Phantom LSD
Reverse Idler
Heavy Duty 3-4
Our race package is geared toward the more serious DSMers. The all out racers, or week end warrior types. Those who want to fire out of the hole and shift above redline, this is for you. Our Race Package is proven to handle 500+ ft/lbs of torque and shift at over 9k RPM's, you won't be disappointed.
Old 02-08-2007   #3
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: Toms Project...
I don't see a body kit on that list
7/25/09
Old 02-08-2007   #4
Re: Toms Project...
Because there never will be one. I nicknamed this car "The Cure" Basically it was the cure for the ricer in me.
Old 02-08-2007   #5
Re: Toms Project...
Too bad "the cure" cant do anything about the raging HIV you've been carrying around. haha
Old 02-08-2007   #6
Re: Toms Project...
Awesome project, Tom!
The car looks like it's in nice shape. Why gut the interior (judging from picture 3)?
As in a new OEM throttle body, Q45, etc.?
Old 02-08-2007   #7
Re: Toms Project...
4-spider diff needs to be in there.
Old 02-08-2007   #8
Re: Toms Project...
FWD
Old 02-08-2007   #9
Re: Toms Project...
Did you have to call them? I can't get ahold of them through email, or through PM on tooooners.
Old 02-08-2007   #10
Re: Toms Project...
FWD
Why do all that to a FWD?
Old 02-08-2007   #11
Re: Toms Project...
Why not? I had plenty of fun with my FWD.
Old 02-09-2007   #12
Re: Toms Project...
Talk to Barton about how "fun" a relatively high hp fwd car was, seriously.
Old 02-09-2007   #13
Re: Toms Project...
I enjoyed being able to spin them at 70. Its Tom's money, let him do what he wants with it. Lets not have another AWD vs. FWD debate.
Old 02-09-2007   #14
Re: Toms Project...
I agree, Tom do what you want! Buy some slicks and a wheelie bar Thats a big project, its given you alot of headaches, good to see your sticking it out!
Old 02-09-2007   #15
Re: Toms Project...
Yeah i had to call them, The guy Alex answers the phone like its his personal cell phone I think i have heard answers like "What up?" and "speak." LOL
Jakey: Unfortunatly its gonna have to be the stock 2g throttle body being that the Magnus is flanged for one. Anyone know if there is a way to fit the 1g or another better throttle body on a 2g flange?
I actually like the FWD, Sure i would rather have AWD like my Auto GSX was but this car is ten times faster then the Auto.
Slicks are definatly in this cars future. and with the LSD and the DSMLink Launch control i should be able to set my launch pretty well.
Old 02-09-2007   #16
Re: Toms Project...
1G and 2G flange are the same bolt pattern.
Old 02-09-2007   #17
Re: Toms Project...
well that makes things easier thanks shane.
Old 02-10-2007   #18
Jaei Sun
4G63 X 2 = 8G63
Jaei Sun's Avatar
Drives: 06 EVO, 92 TSi AWD
Re: Toms Project...
This guy will take either a 1g or 2g throttle body and bore it out and do a half shaft modification. $140 shipped and he'll take your 2g tb and bore it out and you will have a 62.5mm tb http://www.throttlebodys.com/
Old 02-28-2007   #19
Re: Toms Project...
Heres a couple new pics of the progress.
I have thought about a couple things while the engine is out, And, im am thinking it may be time for a new clutch (southbend), and perhaps maybe going with an SCM61 turbo, which then means bigger injectors, (possibly 1000cc) and some other fun stuff. Im am kinda contimplating it right now. but its likely going to put the project back another month before being complete.
So i have come to a couple questions:
Do you guys think it is worth going from a PTE 50 trim, to a SCM61?
Which injectors should i be looking to get?
Should I wait on the clutch and turbo and just get the car in great running shape, or should i say fuck it and get everything done while the engine is out?
Is there anything else i am missing that you think i may need.
ID:	5191   Click image for larger version
Old 02-28-2007   #20
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Toms Project...
Looking good!
Yes, I would go with the SCM61. They arent really all that laggy.
Is the Magnus intake made different? Looks weird, like it has a patch between 2 and 3 runners. Interesting.
Originally Posted by shoutbox
