Old 06-06-2007   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Bye bye FWD!!!
Well it has been a long process with my car. First it was a 95 FWD talon and then I swapped my parts into a 97 Spyder. I was just getting it ready to dyno after the E-85 conversion and now second gear lost a few teeth.
Now is time for 97 Spyder AWD! I have beed thinking about doing this but have a reason to do so now. So far I have the rear end, gas tank, and the drive shaft.
I am in the process of looking for the other nessicary parts but will keep the progress updated. Pictures to come. Let me know what you think or if I should do anything else along the way.
Amsoil Dealer
Old 06-06-2007   #2
Re: Bye bye FWD!!!
everyone is doing the swap now. good luck if you have any questions just ask me
Old 06-06-2007   #3
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: Bye bye FWD!!!
One question is do I need the rear suspension or just the spindles? And do I need the wiring for the gas tank from an awd shell? PM me if you have any things that I should for sure know that I might miss. Thanks for the help TKR
Amsoil Dealer
Old 06-06-2007   #4
Re: Bye bye FWD!!!
you will need the rear end the fwd knuckles are the same just need the hubs
you will need the fuel tank wiring
Old 06-06-2007   #5
blageo23
AWD4G64
blageo23's Avatar
Re: Bye bye FWD!!!
If you need help with it call me
Old 06-06-2007   #6
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: Bye bye FWD!!!
Thanks for the help and ill probably be calling you BLAGEO. TKR do I need the front hubs or just the back?
Amsoil Dealer
Old 06-06-2007   #7
blageo23
AWD4G64
blageo23's Avatar
Re: Bye bye FWD!!!
You need to change your sig. now
Old 06-07-2007   #8
Re: Bye bye FWD!!!
just the rears
