Old 05-31-2007   #1
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
Tial 38 w/g vacuum line routing
Another vac. line thread. My question is on my tial it has an opening on both sides of it (i'll photoshop a pic), and only have one banjo fitting so I have an open hole and then a spot that has a vacuum source. Is this ok or do I need to order another one and have a vacuum line on both sides of the wastegate? Thanks Ryan
Name:	photoshop wastegate.JPG
Old 05-31-2007   #2
blageo23
AWD4G64
blageo23's Avatar
Re: Tial 38 w/g vacuum line routing
Only one need to be hooked up. I remember reading it on the instructions but I cant remember which one is hooked up.
Old 06-01-2007   #3
Excellent drawing!
I'm pretty sure you leave one of them just open, unless you're going for super high boost.
Old 06-01-2007   #4
On my old setup, I had the hole on the very top of it left open, and I used the one that was on the side. That was with my MBC.
When I switched to a Profec-b, I used the top port.
It was a long time ago so I don't remember the exact resoning, but that is what I was told was the correct way.
Old 06-01-2007   #5
use just the lower fitting the upper is left open (when using the springs in it or a manuel controler)
hook to the top if using a electronic boost controler
Old 06-01-2007   #6
crazy_skier
A.E.K.Δ.B
ok thanks, I just have the lower connected right now. And arent my paint skillz impressive???
