Old 06-17-2007   #1
justinhill
BetHiLow Streak Un-Censored Champion! League Bowling Champion! Snowboard Champion!
Drives: 98 gst eclipse
Send a message via AIM to justinhill
injectors
alright my injectors are clogged and junked im gonna replace them but what size should i get im running the 14b turbo right now but im planning on running a t3/t4 soon
justinhill is offline   Reply With Quote
Old 06-17-2007   #2
Re: injectors
Which one?
Old 06-17-2007   #3
justinhill
Re: injectors
t4 but if i dont do the turbo swap and keep the 14b in what would be a good size to run that
Old 06-17-2007   #4
Re: injectors
OK really, what turbo?
Old 06-17-2007   #5
x-pride
x-pride's Avatar
Re: injectors
The big one and I will take two please.
Justinhill do you even have the mods to support that size of turbo?
Old 06-17-2007   #6
Re: injectors
How about stock 450 injectors if you keep the 14B? If you have a clogged injector and don't upgrade turbos just send yours out for a professional cleaning to FIC.
If you plan on upgrading turbos you better figure out which one you are getting (T4 is not an answer), and you better make sure you have all the mods to properly support it.
Old 06-17-2007   #7
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
Re: injectors
I would reccomend getting some 550cc injectors and an safc, then when you get a logger and fuel pump you can start turning up the boost pretty high. There are people who have run a 50 trim turbo with 550cc injectors to start, if they are at lower boost levels. btw a 50 trim is a t3/t4, and you need to be specific on what size your talking about.... t3/t4 is just a model, like a mitsubishi turbo which is a mitsu flange, while a t3/t4 is a t3 exhaust flange and a t4 compressor housing (correct me if I have them switched please) and then there are sizes..... we dont know if you are talking about a 50 trim or a 70 series turbo
