Old 07-31-2007   #1
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
alternator wire-where does this go?
Where does this go?! It's one of the wires that works with my alternator. I just jacked up my car to fix my i/c pipe and I found it unatached to anything...
help!
pics or gtfo
Old 07-31-2007   #2
joem
Drives: 1991 Talon awd auto
Re: alternator wire-where does this go?
oil pressure switch
Old 07-31-2007   #3
HiImBrian
HiImBrian's Avatar
No wonder my oil pressure gauge stoped working. could you give me a hint as to where that is?
pics or gtfo
Old 07-31-2007   #4
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Its a "round" metal sensor located on the oil filter housing. Towards the oil pan. There is a little nub that sticks out of the bottom that it slides over.
Originally Posted by shoutbox
Old 07-31-2007   #5
HiImBrian
HiImBrian's Avatar
Thanks jake, should there be something plugged into the other side???
pics or gtfo
Old 07-31-2007   #6
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Yes there should, and it should go to the oil pressure sensor pictured on the left. (Round)
Old 07-31-2007   #7
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
The other one should just be for the idiot light though. Not as crucial.
Old 08-07-2007   #8
Wizard
The large sender under the crank pulley is for the gauge. The small one under the alt. is for the oil pressure light.
Wiz
Old 08-07-2007   #9
HiImBrian
HiImBrian's Avatar
Well the idiot light isn't even on. The gauge just doesn't work. I'll just wait for somebody to part their car out and steel the wire from them.
pics or gtfo
Old 08-07-2007   #10
Wizard
Just make it, short piece of wire with a female lug connector on one end to attach to the sender. The factory ones are usually chewed up and oily anyways.
Wiz
pills11.com )
Old 08-07-2007   #11
I should have one on my part out car, $2 and its yours.
Old 08-07-2007   #12
HiImBrian
HiImBrian's Avatar
lmk when you wanna give it to me. I'm too lazy to make one
pics or gtfo
