Old 08-29-2007   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Summer Project done (well its never really done)
The car didn't make it to the cookout as I wanted it to. It was running rough and I didn't want to risk hurting it.
I did want to post pictures of it to show progress. Not all of the photos have been uploaded but I just wanted to show how much work I have been doing on this car.
http://s217.photobucket.com/albums/cc272/Andrew7dg/
This isn't a high budget car with lots of money stuck into it but it does run nice now.
I bought it with a couple of problems which is never the way to buy a dsm
It had a bad boost leak and that was an easy fix
What really bugged me was that it was smoking when it was idling and I thought it was the turbo (when I bought it someone had stuck on a 13g...weird) switch turbos to a 14b and still had the same problem. Then being new to the dsm world I put on a 3" exhaust system and was introduced into the world of boost creep.
just wanted a clean running engine that would be somewhat reliable.This year I finally did something about it. I pulled the engine and changed all of the gaskets along with installing
APR studs
eliminated the balance shafts
Installed the FMIC with hard pipes
Installed 16g (ported)
2g o2 housing (ported)
Evo III exhaust manifold (ported)
New valve cover
Custom made hard intake pipe
2600 ACT with Flywheel
GM MAF-T
I didn't install this all at once however. front mount was installed before I took apart the engine just to make sure it would work.
I just got done and I am quite impressed with the results.
I thought removing the balancing shafts would be annoying when driving but I don't notice it as much as I thought
Anyway I will add more when I find more pictures
Old 08-29-2007   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: Summer Project done (well its never really done)
Looks good. A buget built smooth running car. I can remeber the days.
11.35 @ 120mph
Old 08-29-2007   #3
Looks good man, is that you holding the fuel pump assembly? Don't look so happy! LOL I remember the first time I pulled one out of a 1G, I probably had the same look on my face!
So did you cure the smoking problem? Just curious why you pulled the motor and didn't go through it? Or did changing out all the various gaskets solve it?
Old 08-29-2007   #4
Andrew7dg
Andrew7dg's Avatar
Thats my dad in the picture holding the fuel pump. I am not sure what he thought about that fuel pump. His first comment was that it is smaller then the stock one but I told him it flowed more. He is more of an Oldsmobile person. In that garage there is a 67 442 olds with a 455.
So when I switch turbos and still got the smoking problem I then figured it was the valve seals. Pulled apart head and changed the seals and it doesn't smoke anymore!!! I still feel like I shouldn't let it sit running in the driveway because it will smoke but it doesn't anymore. This may sound weird but the exhaust doesn't stink as bad as it did also.
I built the valve spring compressor out of a broken socket and a C clamp. Worked really well plus inexpensive.
Old 08-29-2007   #5
Nice work! It will not smell as bad because there's just exhaust coming out, not extra crap creeping past the valve seals.
Old 08-29-2007   #6
looking good.
I had almost the same setup on my talon for 2 months till I got board with it and went to a pte 6152
Old 08-29-2007   #7
Yeah, looking nice! 1g's own.
Old 08-29-2007   #8
Andrew7dg
Andrew7dg's Avatar
I like that I am getting good responses and I haven't even shown the completed engine.
Photo bucket has been updated!!!
http://s217.photobucket.com/albums/c...ew7dg/?start=0
One problem that I am having is what to do with the cruise control box. It is in a different place then the 91-94. It doesn't fit around the pipes. I am going to try to rotate the box so that the top cables go over the pipe.
It was a complete accident but the color combination worked out to what I like. It has the primary colors red, yellow, and blue. There is some chrome in there that I thought I wasn't going to like but it worked out. There are also some braided lines in there. Not fake but real braided lines. The valve cover turned out beautiful I think. I used gray primer, masked off the letters and painted the rest red. What I didn't realize was the gray matched the timing belt cover so they blended together. I was going to paint the letters white but I am going to leave it because nothing else is white in the engine bay.
I also liked how the intake pipe worked out. There was some custom welding of 2 3" 45 degree elbows and I put a K&N on the top.
Porting the turbo is one of the best improvements I think I made to the car. No boost creep!!! I hated boost creep. I couldn't go WOT. The flapper only opened like 45 degrees. I couldn't port to the full 90 but I got it to 80 open. I think the 2g O2 housing helped a lot. I ported the outlet to 2.5" to match the exhaust.
Please let me know if anyone has any ideas for the cruise control. I kind of want to keep it.
Old 08-29-2007   #9
Just ditch the cruise control and get a non cruise throttle cable
Old 08-29-2007   #10
X2 on the non cruze
you can use one out of a mirage sence you can find them at u pull it fro next to nothing
Old 08-29-2007   #11
Nice cleanup job on the motor!
Old 08-29-2007   #12
I say stick with the cruise! My car still has cruise and power steering I would get way too many tickets without cruise.
Old 08-29-2007   #13
I love my cruise control, P/S, and A/C too!! Can't wait until I get my leather interior back in as well! Looks like a nice simple and effective setup!
Old 08-29-2007   #14
Haha My car has no cruise, no p/s, and no ac, and I wouldn't have it any other way
Old 08-29-2007   #15
Andrew7dg
Andrew7dg's Avatar
I would get rid of the cruise control if it was a drag car built for the purpose of ET but I want to enjoy the car on long drives as well. I kept the P/S also but I ditched the A/C. I have a sunroof and I figured that will do. The A/C weighs a lot and the cooler blocked air getting to the radiator. I kind of want to keep it some what streetable. I have an S-10 that has no p/s a/c cruise or other added weight. Thats the next project...
Today I tried to start it up and its having a hard time starting... tries to start every once in a while but doesn't stay running. Hopefully tomarrow I will figure out what it is.
