Go Back   MitsuStyle > The Homefront! > Everything Racing
Old 09-05-2007   #1
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Rock Falls Sat. Sept 22
I know everyone's still pissed about the proving grounds. But I cant afford to drive to Iowa right now. Im planning on going to the fun day on the 22nd. We should get a good group together for this event.
11.35 @ 120mph
Old 09-05-2007   #2
Re: Rock Falls Sat. Sept 22
My birthday is the day before. If I get this revving issue sorted out with my car, i'd love to go.
-A. Swift
Old 09-06-2007   #3
I might, same deal with not having the $$ for Iowa, but I have to tighten the FUCKING GOD DAMN flywheel bolts again!! I am so sick of pulling trannies in the damn thing every 150 miles.
Old 09-06-2007   #4
Jet, why don't you just tack weld the fuckers?
Old 09-06-2007   #5
carltalon
carltalon's Avatar
Sweet!! If Swifty Jet and I all show up and run the times our cars are capable of mabey rock falls will see what DSM are really about.
Jet are you using the shorter 7bolt or Supra/ARP flywheel bolts bolts? I know the stock DSM's are to long fot the twin disks. Ive heard its a good idea to run the auto flywheel spacer with the twindisks too
11.35 @ 120mph
Old 09-06-2007   #6
jet? You re-using those? I'm telling ya man, you need help with that fricken car!
-A. Swift
Old 09-06-2007   #7
Drill the bolts and safety wire the bitches
Old 09-06-2007   #8
I am down as long as i can get the day off.
Old 09-06-2007   #9
Yea brownman! I wanna see you run again! shoot for 11's? Get that setup going man!
-A. Swift
Old 09-06-2007   #10
11s might be a bit steep, but i will see and try, i think low 12s for sure.
Old 09-06-2007   #11
santa
Boost Spike
santa's Avatar
So ghetto it just might work!!! I might be able to go. I gotta get a few things inline not car related.
Old 09-06-2007   #12
Where have you seen anything about that? On NABR they are recommending using the auto spacer and LONGER auto bolts, but the head has to be shaved down. That is probably what I am going to be trying this time.
Anyone work at a machine shop with a surface grinder or kinow of someone that does? I could do it myself, but I don't have access to one.
Old 09-06-2007   #13
I don't remember what I did with mine, but I haven't had any problems, at least not with the clutch or flywheel bolts. Which flywheel do you have?
Old 09-06-2007   #14
I used an ARP head bolt washer under the head of each of my flywheel bolts with my twin disc. It didn't come lose even after reving to 11,800, but I never put too many miles on the car, just some trips to Midway and 700whp fun around Elite and on 94.
Old 09-06-2007   #15
Aluminum and steel do not weld together well. We had to shave some bolt heads down on a SRT I just used the lathe. I would just take a thin metal ring that would sit just inside or outside of the bolt head and weld all 6 bolts to it.
Old 09-06-2007   #16
Actually the twin disks aren't aluminum flywheels. I have the Devo one Steve, so it should be a PTT flywheel. I was thinking the same thing John, if they loosen up one more time I will tack weld the bolts to the spacer from the auto, then I can grind the tacks off and not damage the flywheel itself.
Old 09-06-2007   #17
hareboy1979
are there requirements for going to this? helmets etc?
Old 09-07-2007   #18
carltalon
carltalon's Avatar
you'll need a Helmet (snel 2000 or better) they'll check your car. Usually just check that the battery is secured and thet you have a coolent overflow.
11.35 @ 120mph
Old 09-07-2007   #19
If I get tires before then I'll tag along but no racing, haven't been to a track once this year.
Old 09-07-2007   #20
Welcome to the club! It isn't looking good for me either. I think the car's aborted until next year, once the SMIM, fuel system etc goes in.
-A. Swift
