Old 09-16-2007   #1
justinhill
BetHiLow Streak Un-Censored Champion! League Bowling Champion! Snowboard Champion!
Drives: 98 gst eclipse
Send a message via AIM to justinhill
Cool SAFC2 help!
im running rich with t/3 t/4 50 trim 550cc fuel injectors 255 walbro pump 38 mm wastegate i just bought the car 2 weeks ago with these setting does any of that sound good oh and the cel is on for tps but i replaced it with a new one and its still on
Trottle
lo=35% Hi=70%
low / high thrt
1000 -16% -18%
1600 -15% -18%
2200 -13% -18%
2800 -13% -18%
3400 -13% -14%
4000 -11% -14%
4600 -8% -18%
5200 -5% -18%
5800 -5% -18%
6400 -5% -18%
7000 -5% -18%
7600 -5% -18%
justinhill is offline   Reply With Quote
Old 09-16-2007   #2
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
Re: SAFC2 help!
those numbers seem to be in the right range, and sort of following how I had my safc set up, except I was running 680cc injectors so it was alot higher on the %'s and I had my low thr at 25% and high at 75%. I would highly reccomed getting a logger and going from there, they are not to much and will save your butt (so you dont blow it up). Also, what do you have for vital monitoring aka wbO2, egt gauge, oil press gauge?? I would reccomend getting a wideband if you have neither of them, since you can tune for an a/f ratio of 11.1 and you should be more than on the safe side with your egt's. Also, what psi are you running for boost.
Old 09-16-2007   #3
justinhill
Re: SAFC2 help!
i have egt gauge what would u recomend on the throttle % and also there this plug in by the ob2 plug in ill get a pic tommarow my gauge is reading 10 but lse turned it up to 15 psI but i dont know if the gauge is right
Old 09-16-2007   #4
dumb_ricer
Hates Everything
Drives: Neon
Re: SAFC2 help!
1g or 2g? If 1g, 2g MAS?
420A > LS1 > All Else
I > All else
Old 09-16-2007   #5
driftn1g
Re: SAFC2 help!
is this with a 2g mas? how much boost??
curious because im currently trying to tune my car too
Old 09-16-2007   #6
justinhill
Re: SAFC2 help!
2g at 15 psi
Old 09-17-2007   #7
Re: SAFC2 help!
How do you know it's running rich? Do you have a wideband on the car? These cars have to run richer than most under boost.
Your Lo and Hi throttle points should probably be more like 25% and 50%. Your RPM point %s don't look horrible, most cars with your setup might be a bit farther negative, but that varies from one car to the next.
Did you actually correctly adjust the TPS? You can't just throw them on there.
Old 09-17-2007   #8
justinhill
Re: SAFC2 help!
i dont know if i put the tps in right. its running rich it back fires some times and there alot of un burn gas coming out the exhaust
Old 09-17-2007   #9
Re: SAFC2 help!
FYI - When fuel burns it creates mostly CO2 (carbon dioxide) and H2O (water). Chances are what you see is water and not unburnt fuel.
Old 09-17-2007   #10
justinhill
Re: SAFC2 help!
true true but when i just start the car and wait a few sec and then go it bogs then after it bogs it will run right
