Old 02-24-2004   #1
john
Business as usual
john's Avatar
After having a walbro 255hp installed, the gas guage doesn't go any lower than just above a quarter tank no matter how low it is. Anybody know whats wrong because I am sick of figuring out I am low on gas when the light comes on. Today it took 23 bucks to fill 3/4 of a tank.
James
This is ghettostylels car. 95 tsi awd. I posted this while logged in under John's name.
97 Viper GTS
Old 02-25-2004   #2
Either your guage is off... if you messed with those. Or the fuel float deal isnt working properly... You could have bent it or something when the 255 was installed.
Old 02-25-2004   #3
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Mine ends up slightly different every time I take out the fuel pump assembly.
Old 02-25-2004   #4
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
What would have caused it. Easy to fix?
7/25/09
Old 02-25-2004   #5
There is a float on a metal rod that moves up and down at an angle... if you bend it a little its off... so unless you know which way to bend it it wont be perfect.
Im guessing that if you bend it straighter it will be able to float farther down into the tank and show less and less fuel.
Old 02-25-2004   #6
The float could be facing the wrong way in the tank and coming down on one of the baffles. Take the sending unit out and look in the tank with a flash light. Put the sending unit back in with the float facing between the baffles.
