Old 11-24-2007   #1
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
wants to die at 4500 rpm at WOT
I dunno what the hell is going on with my car but here is whats happing.
car 98 gst
14b
bolts on and mbc @12 or 15 lbs.
So heres the deal I just had some work done on my car because a exhaust manifold gasket needed to be replaced and so that was done and i was driving back on the freeway and wanted to finally be able to get on the gas and make some boost. Because it was a pretty bad leak and it wouldnt build boost very well. So Im at WOT and at like 4500 rpms the engine just wants to die it felt like it was bogging down and would go over that at all with out dying. I did notice this before about a couple weeks ago and figure it was because everything wasnt able to keep up because of the bad leak. Any input would be great thanks guys.
Tyler Aherns
-USN-
Old 11-24-2007   #2
Re: wants to die at 4500 rpm at WOT
Spark plugs? Wires? How old are they?
Old 11-24-2007   #3
98gstaherns
maybe a year. year and a half? That maybe shit..
Tyler Aherns
-USN-
Old 11-24-2007   #4
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Try a boost leak test.
-1990 Mitsubishi Cyborg 4WD-
Old 11-24-2007   #5
YiNYaNg
Hold Alt & press F4...LoL
YiNYaNg's Avatar
What are your spark plugs gapped too?
Originally Posted by ecoli
Some cars are so slow that even the cops can't tell they are racing.
http://www.myspace.com/kounpheng
YiNYaNg is offline   Reply With Quote
Old 11-24-2007   #6
98gstaherns
whatever they are suppsosed to be at.
Tyler Aherns
-USN-
Old 11-24-2007   #7
YiNYaNg
YiNYaNg's Avatar
Let me guess... you bought them and threw them right in.
Get some new plugs and gap them down to .025 and see if that helps.
*edited*
Old 11-24-2007   #8
tim
tim's Avatar
Get some new plugs and gap them down to .25 and see if that helps.
.025 i think you meant. A quarter inch may be a bit much.
Old 11-24-2007   #9
YiNYaNg
YiNYaNg's Avatar
Sorry for the typo.
Old 11-24-2007   #10
yup yup, boost leak test and some fresh plugs, perhaps some plugwires to boot.
Old 11-24-2007   #11
98gstaherns
*edited*
No I gaped them. I used to work in a shop. Im not that dumb. But ya Im gonna hopefully throw some new plugs and wires in first. But i leave on a deployment in the beggining of dec so it may have to sit and wait a while.
Tyler Aherns
-USN-
Old 11-24-2007   #12
bluntedelvis
Click,Click,BOOM!!!
bluntedelvis's Avatar
I maybe shooting in the wind here, but have you also tried fiddling with the MBC. You dont have it cranked up to max do you?
Old 11-24-2007   #13
98gstaherns
no its not. Even if it was it wouldnt climb that high either way.
Tyler Aherns
-USN-
Old 11-24-2007   #14
YiNYaNg
YiNYaNg's Avatar
Good chance old stuff and the spark isn't getting through strong and getting blown away.
Old 11-24-2007   #15
92Laser
92Laser's Avatar
Make sure nothing is loose on the coil pack and transistor pack(ignitor). When was the fuel filter changed last?
92Laser is offline   Reply With Quote
Old 11-24-2007   #16
You don't think a 14b will overboost a car? Think again! You aren't dealing with a T25. I also agree that the plugs are probably crap. For a street car I would go .028" on the gap, NGK coppers of course.
Old 11-24-2007   #17
98gstaherns
overboost? I havent heard of that. Could you explain what you mean. I think I have a idea just by the name.
Tyler Aherns
-USN-
Old 11-25-2007   #18
iceminion
iceminion's Avatar
you need not worry about overboost if you actually are somewhere between 12-15psi at WOT.
Bad gasoline will cause excess knock, your engine will pull timing, it will feel like the car is falling on its face, this means your knock sensor is working.
I know they dont teach you much in the Gavy, but I will share some Army knowledge with you: Get a datalogger and see whats going on during the malfunction.
building a 3000GT AWD Turbo.
Old 11-25-2007   #19
98gstaherns
Hey there. They teach me how to fix hydraulics and servos, but not engines and turbos.
Tyler Aherns
-USN-
Old 11-25-2007   #20
Army FTW, Hooooaaahhhh!!!
Overboost, it just sounds like you think the 14b couldn't make too much boost, even if the boost controller was set wrong. If you are between 12-15 psi for sure, then you are fine.
