Old 12-09-2007   #1
iceminion
iceminion's Avatar
having N00b problems.....
91 Tsi AWD 5speed
Car ran fine, oil filter spun off, had to rebuild the bottom end
compression after rebuild (65 100 70 65) (rings have not seated, engine has not run yet).
New temp sensor -- tried 2 known good ECUs -- ~40 PSi of fuel -- FIC 550cc's -- spark in all 4
The timing is correct! done it on at least 10 timing belt jobs!
While I crank the car, it tries to stutter to life, but fails
I completely disconnect the GM MAF, still stutters.
Any ideas? I have double checked pretty much everything? what else would cause a car not to start?
Thanks alot!
building a 3000GT AWD Turbo.
Old 12-09-2007   #2
Re: having N00b problems.....
CAS 180* out?
Old 12-09-2007   #3
iceminion
iceminion's Avatar
seriously? is that even possible? *goes out to garage to check*
Old 12-09-2007   #4
Yep, it is and happens often.
Old 12-09-2007   #5
Or, did you put that thin metal spacer between the timing belt and balance shaft belt gears (the one you use to align the crankshaft timing mark) on backwards your timing will be off, and the car won't start. Thanks to a friend, that happened to my old car, wouldn't rev past 3K and was all sputtery.
Old 12-09-2007   #6
driftn1g
it was the cas on wrong
Old 12-09-2007   #7
iceminion
iceminion's Avatar
Uh, No
Good call JET, it COULD have been the problem.
The CAS was on correctly, I know this because there is a dot on the CAS and a dot on the cams, they lined up properly.
im going to double check the GM MAF.
And thanks swifty, ill look into that, i hope thats the problem.
Old 12-09-2007   #8
iceminion
iceminion's Avatar
As you can see from the cell phone picture (sorry for the blurryness) the timing/balance belt separator is indeed installed properly, please note the black crap that has built up over the years is only worn out where the timing belt has kept it polished clean.
And yes, even though it is not shown in this picture, the timing is done correctly.
swapped out ECUs, put 450cc's in and re-configured the GM MAF.
it kidna burped, but then no, nothing....
I pulled the spark plugs and added oil to simulate compression. Kinda added a little much to one cylinder
125 - 125 - 200 - 175
Still nothing....
Old 12-09-2007   #9
It's worth a shot to just flip the cas around and try. Also, what are you using to tune, and are the plug wires in the proper order?
Old 12-09-2007   #10
iceminion
iceminion's Avatar
Actually, its not "worth it" to flip the cas around and "try".
What is worth it is to look at the alignment dots and align the CAS.
1 and 4 go to the front coil.
2 and 3 go to the rear coil.
GM MAF and SAFC for tuning.
what should the karmen read while starting? its at a solid 3 when the car is not running, and it doesnt go up much while cranking...
Old 12-09-2007   #11
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Calm down n00b fucker, YOUR the one on here asking for help......
Old 12-09-2007   #12
iceminion
iceminion's Avatar
Don't even try to talk down to me boost creep.
There is no "try" when you are working on a car, everything you do needs to be "CORRECT"
if anyone has anything more to suggest, say it now, otherwise this car gets pushed in the lot and I start working on my galant.
Old 12-09-2007   #13
How else are you going to fix the problem when no one knows what is causing it to begin with? Have you ever heard of troubleshooting? Trial and error is your friend and none of the suggestions given to you already are going to hurt anything. Your attitude right now is what makes people not want to help you in the future.
Old 12-10-2007   #14
Um, you are the one who titled your own thread "having N00b problems.....". We are just trying to help, if you do not want the options you have to try, then push your pile in the lot and do not ask us for our opinion, only to be a dick after you have heard your options. And maybe you should listen to some of the advice YOU asked for, the people at the other end of the keyboard may have a bit more experience then you(specially considering the title YOU made). I'll be sure to try and never help you again. Thanks.
Old 12-09-2007   #15
b00stcreep21
I hate everyone
Push the car in the lot please
Old 12-09-2007   #16
If the MAF signal does not deviate from 3, it sounds like there is a problem with the MAF-T. I had this problem before, and if it's solid at 3hz, something is goofy with it. Mine had a leaky cover and was getting moisture inside the box.
So, clean that out, check the wiring, and if that doesn't work, try hooking up/plugging in a stock MAS.
Old 12-10-2007   #17
Yeah dude stop being a dickhead. are you sure your SAFC is wired up correctly/ setup correctly. DOUBLE CHECK THE CAS. and if you look at a manual you will notice that you dont line up the CAS with the "dot on the camshaft", you line up the dot on the camshaft sensor housing to the dot on the "plate"(the part that spins). Also like Sleepy said make sure that plate is on correctly(im the dickhead that put it on wrong cuz he was fighting with his bitchy ass girlfriend)! Make sure the MAFT is wired correctly...
Old 12-10-2007   #18
iceminion
iceminion's Avatar
This is Berda's car, the SAFC and GM MAF were working when the motor was removed.
This is some of the worst wiring in the world, so maybe I was wrong to assume that the gm maf was connected correctly...
The next step is to remove the GM MAF and SAFC completely. get a 1G mas and another ECU. Bring everything back to stock.
Old 12-10-2007   #19
So obviously something changed when the motor was removed and put back in. Figure it out, smart guy.
Old 12-10-2007   #20
Right now, I'd put my money on the MAF-T or the GM MAF.
