Old 04-07-2008   #1
yang
Drives: 97 GST spyder
1st gear pops out and grinds...
Hey guys I just picked up a 97 gst spyder fwd. My first gear pops out and grinds like crazy so I've been driving it on 2nd gear. I havent checked the fluids yet but I just got the clutch done at the shop. All the other gears work flawlessly. Is it time for a new tranny?
yang is offline   Reply With Quote
Old 04-08-2008   #2
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: 1st gear pops out and grinds...
or a rebuild, sounds like the synchros are done in gear 1.
Old 04-08-2008   #3
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Check simple things first.
I thought I was going to need a new transmission also but shift linkage was loose. Popped out of gear like you said but all of the other gears worked well.
Just check to see if yours is loose. Try shifter bushings also.
"makes it shift like a bolt action rifle"
Old 04-08-2008   #4
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
Mine did the same thing when I first got my AWD. I checked everything, adjusted linkage, got a new shifter, etc...
The only thing that helped was a stage 2 TRE rebuild.
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 04-08-2008   #5
The syncro/hub sliders are worn out. You need a rebuild, there isn't any other "easy" fix. www.sheptrans.com I have a Shep stage 3, and love it!
Old 04-08-2008   #6
Yep, probably need a rebuild. You might be able to adjust the linkage and limp by with it for a bit.
Old 04-08-2008   #7
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
mine did the same thing 2 days before second gear cut its way through the case.. pretty crazy
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 04-09-2008   #8
yang
Hey guys thanks for all the comments! I will look into bandaging it up for now. I really dont want to invest too much yet because I might sell this in a year or so. I just need a daily driver for a couple of months until next fall. Thats when I'll be rebuilding the tranny or selling the car.
Old 04-09-2008   #9
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
This just came to mind, if your interested my buddy has a brand new in the box TRE Stage 1 never been used. I do not know what he is willing to let it go for, but its a very nice transmission.
-Matt
'06 Acura TL
Old 04-09-2008   #10
yang
awdgsx13, can I get some contact info? I'll think about it.
Old 04-09-2008   #11
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
just pm me, he payed 2500.00 for it if i remember correctly so the price im assuming will be right around their. If interested shoot me a message.
-Matt
'06 Acura TL
Old 04-09-2008   #12
yang
A little to steep for my pockets. I might just go with the sheptrans rebuilt for 995. thanks though
Old 04-10-2008   #13
User Name
User Name's Avatar
A stage 2 from TRE is under $1800...
TRE is taking a break until the 18th though.
ForSale:
FIC 850
FP Turbo kit
Old 04-10-2008   #14
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
it may be a different stage/options not sure exactly.
-Matt
'06 Acura TL
Old 04-10-2008   #15
User Name
User Name's Avatar
True. I forgot about all the add-ons you can do.
They're having a sale at TRE on trans. But, they're not taking any orders until the 18th, as I stated before.
www.teamrip.com
ForSale:
FIC 850
FP Turbo kit
Old 04-11-2008   #16
yang
User name, thanks for the link. I will talk to Jon next month about an exchange buildup
Old 04-11-2008   #17
turbo-soundz
How many miles already on the Spydie?
LMK, when you let go of that car.
turbo-soundz is offline   Reply With Quote
