Old 02-21-2004   #1
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Just looking for thoughts on this. I know that the stock head will work with the 414's and 272's. Any major things to worry about? I know Nash nuked 2 14B's with 272's. Any thought's on this issue? Run less boost (16psi?) and avoid it? Quick replies would be great.
Old 02-21-2004   #2
I can't speak for the 414's (never ran them) but the HKS 264/264 & 272/272 cams work fine with stock head, gears and springs. The same rpm limit applies as it would with the stock cams (because of the stock springs). Boost is not an issue, I ran up to 24-25psi on both set of the HKS cams with no problem (22psi on my 16g).
Old 02-21-2004   #3
MustGoFaster
I was just thinking that Nash killed his 14B's due to high shaft speeds by trying to run 20psi (IIRC) on the 14B with cams that flowed well. I want to keep my 14b in one piece for the time being.
Old 02-22-2004   #4
Going fast is about matching parts correctly. Race cams and a dinky stock turbo don't fit this pattern. Save your money for other stuff like a bigger turbo.
Old 02-24-2004   #5
http://www.stealth316.com/images/td05h-14b-cfm.gif
Looks to me it would have fun with some help 'up top'
go for it, if it spins apart, well you need more turbo .
Old 02-24-2004   #6
I wouldn't put much weight into the data found on that Stealth316 site.
Old 02-24-2004   #7
john
Business as usual
john's Avatar
I had 264's on my 16g setup. I didn't notice much of a difference. Maybe on the new turbo it will help more...
97 Viper GTS
Old 02-26-2004   #8
crazyboost
Here are some numbers from when AMS tested several cams on 1g with a 16g and all the supporting mods:
Cams Tested:
Stock Mitsubishi
Web Cams - Street Grind
HKS 264 intake 264 Exhaust
HKS 264 intake 272 Exhaust
HKS 272 intake 272 Exhaust
Crower - Stage 3 Grind
Jun Stage 3 Grind
Peak Horsepower and Torque Results:
Stock Mitsubishi Camshafts:
Peak HP: 309.5
Peak TRQ: 295.3
Spool up on street: quick, full boost by 3.2K RPM in 3rd gear with good power when off boost and as it's coming onto boost.
Web Cams - Street Grind:
Peak HP: 314.3
Peak TRQ: 295.3
Spool up on street: slower than stock, full boost by 3.4K RPM in 3rd gear with less power off boost than stock cams.
Peak HP: 322.6
Peak TRQ: 314.0
Spool up on street: much slower than stock (the worst of all the cams) with full boost hitting by 3.6-3.7K RPM and a definite loss in power off boost compared to stock cams.
Jun Stage 3 Grind
Peak HP: 323.7
Peak TRQ: 323.2
Spool up on street: Car was not driven on the street.
HKS 264 Intake 264 Exhaust
Peak HP: 323.1
Peak TRQ: 333.0
Spool up on street: As good as stock (3.2K RPM), with off boost power the same if not better than stock.
HKS 264 Intake 272 Exhaust
Peak HP: 324.2
Peak TRQ: 333.1
Spool up on street: Slightly slower than stock (3.3K RPM in 3rd gear) and a very slight loss in power in off boost conditions.
HKS 272 Intake 272 Exhaust
Peak HP: 325.2
Peak TRQ: 323.4
Spool up on street: Slower than stock, full boost by 3.4K RPM in 3rd gear with a slight loss in power in off boost conditions.
It seems that the HKS dominate with the smaller turbo, I would say with even a smaller turbo like the 14b, the hks 264/264 or 264/272 would be your best bet. This would give you a close to regular idle while still keeping a lower end powerband pretty similar, and increasing the top end power significantly. If you plan on going with a large turbo (20g and up) in the future I would suggest getting the hks 272/272 because they seem to prevail when flowing huge numbers. Not quite sure how that would work with the 14b though (rough idle). I would first suggest getting all the supporting mods so you can get the most out of your cams.
crazyboost is offline   Reply With Quote
Old 02-26-2004   #9
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
They work awesome with a 14B as well, and I love the idle.
272's all the way when it comes time for cams.
Old 02-26-2004   #10
john
Business as usual
john's Avatar
272's on a 14b is the way to go):
97 Viper GTS
Old 02-27-2004   #11
How much are the cams? I would not risk 272s and a stock turbo, and $600 for 30hp is a little out of wack(if the 14b would even pick that much up). I would imagine the 414s are similar to the 264s, so I dont think you would get more than 18-20hp. You already have 93cams, stay with those and when you buy a really turbo get the good cams.
Old 02-27-2004   #12
You should get more than 30hp with the HKS cams with supporting mods.
Old 02-28-2004   #13
A 14b is not a supporting mod, which is the turbo being used in this set up. And I do not think running less boost would help much. Also you could see if your 14b is a lefthand thread or not.
Old 02-28-2004   #14
Did anyone even read what crazyboost posted above? Don't expect a huge HP gain from cams. There will be a good gain in the 7000-7500 range(I dunno about with a 14B that doesn't flow crap at that level), but not a lot of a peak HP gain. the 10-15HP gain that AMS got in their testing are right inline with the gains that I have got on cars that we put cams in, even ones with bigger turbos. Even HKS 272/272s are no where near a wild cam when compared to the cams you see on domestics and VTEC cars. To run an aggressive cam in our heads you need to cut down the valve guides to actually get some high lift. Cams are a decent mod, but they can be put off for quite a while. I would like to see what the power curve is like on a car with a sheetmetal intake and stock cams. With aftermarket cams the power still starts falling in the 6500RPM area, it usually take a sheetmetal intake to hold the power out longer or have it keep rising.
