Old 05-04-2008   #1
Supa_dupa_man
Bimmer Guy
Supa_dupa_man's Avatar
Drives: ///M3
Help again
Ok, so I got my car runnin a few days ago, I havn't put many miles on it yet, but Im running N/A again just till the motor breaks in. Well today I was driving into town and all of a sudden my car gets louder and really gutless, like it had very little throttle response, and I started to smell raw gas, I was like wtf. The car started chugging and chugging, so I pulled over at my buddys house that I was comming up to. shut the car off asap, and let it sit for a bit to figure out what the deal was.
I popped the hood and started the car, There was exhaust shooting out of the hood. well, one of the bolts that holds the downpipe to the header broke out, so I put a new one in, tightened it down. then I went around to the back of the car and checked the exhaust and it was white, and the car was still sputtering but it idles at 2000ish RPMs. There is also some gas comming out the exhaust. I don't think I popped a head gasket, because I just put a cometic, copper sprayed HG on and ARP head bolts.
My Air/Fuel guage says Im running super rich. My nitrous LED guage also says the same thing. Im running the stock FPR, stock injectors, and stock Fuel pump again, and the problem seems to be the same.
Anybody got some Ideas
MMFTW
Supa_dupa_man is offline   Reply With Quote
Old 05-04-2008   #2
Supa_dupa_man
Bimmer Guy
Drives: ///M3
Re: Help again
Could a bad upper o2 sensor have anything to do with all this? The header/downpipe is still leaking exhaust
MMFTW
Old 05-05-2008   #3
Flipboi89
Flipboi89's Avatar
Drives: 2gnt
Re: Help again
Are all of your cylinders pressure normal?
Flipboi89 is offline   Reply With Quote
Old 05-05-2008   #4
x-pride
x-pride's Avatar
Re: Help again
So is your car turbocharge or not? It does not matter if you just replaced the head gasket. If the surface is not even and clean than it will cause a problem. You said you smell gas. Gas as in gas or exhaust gas? More detail about your car please.
Old 05-06-2008   #5
Re: Help again
You probably popped your head gasket. I've not heard many good things about Cometic head gaskets.
Old 05-07-2008   #6
Supa_dupa_man
Bimmer Guy
Drives: ///M3
Re: Help again
Not currently boosted... no turbo... The car idles high like 2000rpms... yes cylinder pressure is good, its 180 all the way accross. My HG should be fine yet...
I did the Key Dance and got these numbers...
24 27 24 11
Im using this site to check them out...
http://www.2gnt.com/www/files/pcmcode.htm
Im kinda confused on what it could be still...
MMFTW
