Old 06-12-2008   #1
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
how many engine mount can I take out at 1 time
Just wondering how many engine mounts I can take out of the car safely at 1 time. I have the drivers side, and front mount already out. I am wondering if I could get away with taking the back mount out also. I have the drivers side of the engine supported underneath.
Anyone have a few tips for getting the back mount out?
Old 06-12-2008   #2
Re: how many engine mount can I take out at 1 time
i wouldnt take out any more. The whole engine will drop considerably if you only leave the tranny side in.
To take the back one out i suggest taking out the bolts mounting the mount to the tranny first. then takeing out the bolt going through the mount. Support the tranny with a pump jack to take some of the pressure off of the mount.
Old 06-12-2008   #3
He has a 1G. On the 1G there are 3 mounts attached to the block and only 1 on the transmission.
I would not take out any more mounts unless the engine is being held by an engine hoist. The rear motor-mount on the 1G is the biggest PITA. I would have 3 the other mounts in place before removing/replacing that one.
Old 06-12-2008   #4
bertrenolds5
Do you have to get uner the car at all to do the back one?
Old 06-12-2008   #5
Its been many years so I don't remember exactly, but I recall getting at the bolts from above the engine bay. Are you just replacing the mounts or what are you doing?
Old 06-12-2008   #6
No.
WHy are you removing all those mounts?
Old 06-13-2008   #7
bertrenolds5
I am filling them with cutting board plastic like the v-faq, then covering it with window weld. It has worked out quite nicely, I just wanted to do as many as possible because you have to wait for them to dry. I think I am going to lay on the engine for the back mount when I get my car off the ramps.
Old 06-13-2008   #8
bertrenolds5
Has anyone taken out the back mount and then the side mount at the same time? 2birds with one stone is what I am trying to do.
Old 06-14-2008   #9
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
I wouldnt reccomend it unless you have support under there, since there is only the one side mount for the tranny.
Old 06-14-2008   #10
bertrenolds5
I think I would suport it then take the back out and then the side. I am not a sober gopher. Here is what I did with the front mount.
