Old 06-16-2008   #1
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
SS oil feed for 14b
Does anyone know if anyone sells SS oil feed lines in the cities? I probably need one for my 14b, feeding from oil filter housing.
Old 06-16-2008   #2
GnArKiLl
GnArKiLl's Avatar
Re: SS oil feed for 14b
where are you tapping into your filter housing?
Old 06-16-2008   #3
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
in the same spot the original line was for the t25; this is on my 2g.
Old 06-16-2008   #4
I bet MAP and/or DB does.
Old 07-05-2008   #5
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
Is their really a benifit from running off the filter housing besides having filtered oil running through the oil?
Old 07-05-2008   #6
Higher oil pressure too.
Old 07-06-2008   #7
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Rumor has it that the 14b turbo can't take the extra added pressure from the filter housing. 16G turbos are ok
This is just what I have heard...
