Old 07-08-2008   #1
Ta_ser_t_s_x21
Ta_ser_t_s_x21's Avatar
Drives: I drive a 1992 Talon TSI
cooling fan wont engage
So have been having issues with the car heating up. Changed the thermostat, but noticed that the the cooling fan will not turn on. The fans will turn on when the AC is on. Any ideas on what the deal is?
Ta_ser_t_s_x21 is offline   Reply With Quote
Old 07-08-2008   #2
Re: cooling fan wont engage
Stock fans? Aftermarket home wired in slim fans?
I'd try replacing the temp sensor/switch located on the bottom of the radiator for starters.
Old 07-08-2008   #3
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
I can't help much, but I can give you some starters, check the relays and fuses maybe? Have you done work to the car recently? Connections?
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 07-08-2008   #4
Ta_ser_t_s_x21
I didnt mess with the wiring of the car, I just did a front mount kit about 2 weeks ago. And installed a new radiator, with the stock fans remounted on there.
Old 07-08-2008   #5
Try the temp switch/sensor located on the bottom of the radiator. Make sure it's plugged in. If so, try swapping it with a known good. It is what tells the fan to turn on when it reaches a certain temp.
Old 07-08-2008   #6
Ta_ser_t_s_x21
I will give that a shot
