Old 07-05-2008   #1
7GProject_4G64
Drives: 1995 Galant ES
Galant Question
Does anyone know where the 1995 Mitsubishi Galant engine mount is located? And is it easy to replace it yourself or would it be better to let an auto shop do it?
7GProject_4G64 is offline   Reply With Quote
Old 07-05-2008   #2
Re: Galant Question
Which one do you need to replace and why?
Old 07-05-2008   #3
7GProject_4G64
Re: Galant Question
Thats what I don't know cause I don't know which one broke engine keeps jumping thats whyy. how many are there? just tell me where all of them are.
Old 07-06-2008   #4
Re: Galant Question
I would guess the 7g galant is similar to the 2g under the hood. One mount will be on the timing belt side of the motor, higher in the engine bay right in front of the strut tower. Then there will be 1 and the end of the transmission bolted to the frame rail. Then there will be 2 torsion mounts in the front bottom and rear bottom of the transmission where it bolts onto the block, I would think its one of these if the motor is moving a lot front to rear.
Old 07-07-2008   #5
7GProject_4G64
Re: Galant Question
to replace the mounts in the front and rear would I have to take out the engine? Or can I just put the jack under the engine to hold it up while I put in the new mounts.
Old 07-07-2008   #6
polishmafia
Smells like cat poop
polishmafia's Avatar
Re: Galant Question
replace them one at a time. you could also post this on TGC cause there are 7G owners there.
Old 07-07-2008   #7
7GProject_4G64
Re: Galant Question
I did but they didn't post anything so I posted it here instead.
Old 07-08-2008   #8
Re: Galant Question
I would do 1 at a time and you should not have to pull the engine, this is not a clutch job on a Saturn.
Old 07-08-2008   #9
7GProject_4G64
Re: Galant Question
Yeah It be best to do one at a time. Gonna replace the front and rear mounts and the transmission mount. It The clunk is from the rear of the engine so I think it's the rear mount or tranny mount.
