Old 09-17-2007   #1
Project Porting! Pics!
So I'm kind of gunning for ~350whp on the stock 05 evo VIII turbo on pump gas. I do run alky injection, but I'm only running ~24psi so its really only used for a safeguard against bad gas (a lot of evo8 guys run 22.5 psi on pump gas, evo IX guys run almost 24!).
So, since this is my daily warrior, I am trying to keep it as reliable as possible. It has been tough, but I have yet to touch anything related to the turbo, or taking much apart.
This will end now. But, I am only planning on taking it apart once, and doing it right!
Here's where I started, with ~305whp. My car has HKS 280's, a TBE with a high flow cat, a upgraded FMIC, and the SMC alky kit.
Old 09-17-2007   #2
Re: Project Porting! Pics!
First thing's first, about 6-8 weeks ago I ditched the high-flow cat in favor of a testpipe. The change was semi-dramatic, with midrange torque feeling much better, improved spool, and high end power is definitely up a solid 10whp.
Look! A Turbo! LOL!
Old 09-17-2007   #3
Next up is the o2 housing. This is a big thing for the evo guys on the stock turbo. At anywhere from $60-400, there's a ton on the market. Most are shyte, some are good, some are 'the best.'
The easy o2 housing to get now-a-days is the megan, and all the cheapos on ebay are rumored to be crap and cost cause boost creep (is this really a bad thing on a turbo that tapers anyways? meh...). Most on the market are supposed to be worth around 10whp, but buschur swears that this ebay (SSAC) housing that he ceramic coats and resells is worth a solid 15whp.
So please note, I'm not *saying* this thing is 'the best', just passing on info I've found and seen to be dyno proven on some of the bigger evo boards.
Old 09-17-2007   #4
Next step back in the exhaust side is the turbine housing. I purchased a $30 air-powered die-grinder and $5 worth of carbide bits. This will be used to lightly port my turbine housing. The 05 Evos have the big 10.5 turbine housing from the factory, so all that's really needed is to port-match the twin-scroll inlets, facing the exhaust manifold. I'll snap some pics of this when I do it.
Old 09-17-2007   #5
blageo23
AWD4G64
blageo23's Avatar
My mom buys those red vines all the time
But that all looks good man.
Old 09-17-2007   #6
Last piece on the exhaust side of the engine (save for the head itself) is the exhaust manifold. Buschur sells these puppies ported and ceramic coated for a decent price. This is supposed to be worth ~5-7whp. We'll see
Old 09-17-2007   #7
As a comparison, here's a pic of how much material is removed from the twin-scroll outlet of the manifold, facing the turbine housing:
courtesy: Warrtalon
Old 09-17-2007   #8
This will be about it for the hotside, dyno results to come on the 2007 MitsuStyle.com Fall Dyno Day!
Up next will be (hopefully) a ported intake manifold and ported stock throttle-body. The stock unit measures 59mm on the inside, and can be easily ported out to 65mm. Please note, 65mm = 2.5", same as my intercooler piping (and most everyone elses). The IM inlet is ported to match, and then the runners are port-matched for optimal power. These together are a dyno-proven 15whp+ on the stock turbo, so I'm hoping this will let me reach my goal of a super solid, mostly stock, DD.
Old 09-17-2007   #9
I hope their dyno proven results aren't like the 15-25whp gains you are supposed to get from swapping FMICs on Evos.
Is the O2 housing really a ceramic coated SS autochrome unit?
Old 09-17-2007   #10
blageo23
AWD4G64
blageo23's Avatar
Sorry I kinda posted in the middle of you explaining things. You can delete that so its not in the middle. But again that all looks nice. Hope you hit your goal.
Old 09-17-2007   #11
Looks good, lets install it on Thurs!
Old 09-17-2007   #12
Buschur is quite a salesman. The porting is worth something though, at least it was on the DSM's when we were doing this BPU stuff.
Old 09-18-2007   #13
Ya, I hope so to. If not, it'll come back off and I'll go a different route I have no idea if these are really SSAC units, all of the 'good' ones have been on back order for months. Rather than take my chances with the various units on the market, I just decided to go with one that someone actually has 100% good stuff to say about them.
Whatever Mr. Going-back-to-small-turbo! Tons of fun to be had with a 16G and you know it!
Old 09-18-2007   #14
16G is definitely a ton of fun, but EVO 3 for DSMs all the others not worth it, if i did it again i wouldn't have this one.
Looks like its time for you to make some big power, reliability is all in the tune and quality of parts used and maintenance, some dsmer has been running his car for the last year and a half making 600hp and 500tq.
Cruise should be good this year again.
Old 09-18-2007   #15
That's awesome, but ahh, those numbers sound a little inflated.
That o2 housing looks like where the wastegate flow re-enters is really small, can that be enlarged?
Old 09-18-2007   #16
Squeezing every once of power out of that stock turbo arent you! haha
Old 09-26-2007   #17
Update! This was a little delayed, as the o2 sensor was not super psyched about leaving the stock o2 housing, so I ended up replacing it
First off, BIG thanks to Chris Hughes (s2kracka) for overall help as well as some guidance with the porting I wanted to do. We ended up taking a bout 1-3mm (maybe 4mm on one side? I can't remember!) of of various portions of the twin-scroll turbine inlet. Nothing major, but in the end I would say it is definitely worth doing. Sorry I did not get a before pic, but here's after. We basically just gasket-matched it, just like the exhaust manifold is:
[img]http://www.scheides.com/albums/evo8/IMG_2874.sized.jpg[img]
We also found a little lip inside the o2 housing that we decided to mow down just a little bit. Again, nothing major, just trying to smooth out exhaust gas flow:
Old 09-26-2007   #18
Here's one thing that floored me. Check out the stock vs ported exhaust manifold:
Stock:
Ported/coated manifold by buschur racing:
(hughes is confident he can reproduce this with some time and a bunch of porting bits)
Anyways, it is obvious that this is definitely worth doing.
(sorry for no more close-up pics here, but the runners are port-matched, opened up a little bit each)
Old 09-26-2007   #19
Install pics:
All buttoned up:
Thoughts/Review:
Well overall, install for all of this, including doing the porting was right around 3-3.5 hours. Not bad at all, and I would say performance wise this is a big bang-for-your-buck set of mods. Turbo spool-up is improved, midrange torque feels stronger, and top-end feels good. My test-drive was out in the rain, so I'll update this tomorrow after I more through test.
Old 09-26-2007   #20
Porting gains are nice, it certainly doesn't hurt, doesn't cost much if you do it yourself, and it's completely undetectable.
BTW, I didn't downsize, my package is on it's way from FP right now.
