Old 06-15-2008   #1
2gREDTsI
FS:92 Talon Tsi AWD 6/4 combo 5 spd--$1350(SOLD)
Up for sale is my 92 talon tsi. I bought it as a project car and lost interest. It is awd and has the 6/4 combo with just over 121k. It runs and drives but has some issues that need to be addressed to be 100% road worthy. After the car is warmed up it smokes whitish blue when you give it gas. I have been told and believe it is valve seals as it is a higher mileage car and is a very common problem with dsms. Also one of the seals in the transfer case is bad(which is why I suggest towing it home). One day after moving it to a different spot in the driveway I noticed it was slowly leaking and I am sure there isn't much fluid left in it. Lastly it has a crack in the winshield and no ac. That is it for the negative stuff. Good stuff is it has a pace setter tubular manifold with no cracks(new gasket and all new exhaust manifold studs and nuts),19c frank jr turbo,and then a 3" punishment racing o2 dump linked up to a modded stock dp with no cat and then 2.5" ss exhaust made by map perf. with a maganflow muffler, Also has a homemade intake for a 2g mas which has a new cone filter,mbc,dual gauge pod and center vent pod for safc and gauge,EPROM ecu that is socketed which currently is running the stock chip(was rebuilt a little while back) new hatch struts,lastly it has a good ACT 2900 clutch and also have the skateboard bearing mod and it shifts nice. It has a pretty solid body no rust except some under the pass sideskirt which can't be seen and then some is starting on the bottom of the doors. The car has black paint in the engine bay and under the hatch(was going to paint it black) only things left is the door jams and under hood as they are still teal rest of the car is black primer and has been wetsanded but still needs some work. I think that sums it up. To those interested I will gladly start it and show you it moves but will not let anyone drive it because of the transfer case leak. I need to get rid of this because I have my srt now and it is taking up space in the driveway. I want $1,350obo for it. You could part it out for more then that but just want it gone.It has a clear title.
My name is Kevin and my number is 651-341-2992-If I don't answer leave your name and number and I will get back to you.
located in Rosemount
Pictures are worth a 1,000 words so here they are. I want people to know what they are coming to look at so you don't end up wasting my time and yours.
thanks
2gREDTsI is offline   Reply With Quote
