Go Back   MitsuStyle > Hosted Support Forums > JET's Customs
Old 03-31-2005   #1
New intake manifold
I have developed a new intake manifold for 1g's. I have spent the last 2 1/2 weeks designing it in the CAD system at work. It is set up for a gasket matched head and has tapered runners. The flanges are 3/4" thick and CNC machined. The runners have a 1/2" radius going into them and the TB flange has a radius going into the plenum (noone else does this). It is all 6061 aluminum and TIG welded. I have TB flanges for both a stock or Accufab 75mm TB. It has 4 vacuum ports on it. It also has built in mounting points for the coils! Noone else does that either. It faces the coils towards the engine, so it should look sharp. Fully polished of course!
Martin from AMS has been developing an intake manfold for the EVO and I hadn't seen his posts until last night. Surprisingly we came up with nearly identical designs! I guess my research paid off. He tried many different designs and settled on the one very similar to mine. Mine has a little bigger plenum than any other manifold on the market, and should work better with a 2.4l.
I would like to know who is interested in buying one. I need to decide how many I need made up for the 75mm TB. I am guessing just mine though The parts are in production at the machine shop right now and they should be done in 3 - 4 weeks max.
I have a snap shot of the bottom of the plenum that hooks into the runners on my webisite http://www.jetscustoms.com . The site is still in progress, but you can see a bit of it on the front page. I may put a few more shots up here.
Price is going to be $450 or under.
Old 04-04-2005   #2
Re: New intake manifold
I don't want to sound like an ass, but are any of these manifold designs patented or in the process of being patented (i.e.- Martin's). It definitely wouldn't be cool to see you get in trouble for having something so similar.
Old 04-04-2005   #3
Jakey designing a intake manifold is like re-inventing the wheel anyway. No matter how you make one you would be copying someones previous idea. There are a few unique ideas going into this intake manifold that have not been shown or talked about yet as well, that will seperate it from some of the others.
CRAIG
Old 04-05-2005   #4
well I'd possibly be interested in one, but I would want to see it first. How long are the runners? When you say the runners have a 1/2" radius going into them, I really am not sure what you're saying, so could you maybe break it down Barney style for me. This uses velocity stacks? Is it just a square plenum, or does it taper like the magnus? I'm really curious about it. I wish you had a picture of what this will look like.
Old 04-05-2005   #5
It definately isn't similar enough to be a patent infringement and I am sure he isn't patenting it anyway. The runners are a total of 6" long. The style is similar to a BJ's manifold. The radius'd runners act much like a velocity stack and the runners are tapered like a velocity stack. The radius is in the pic on my website. www.jetscustoms.com
I am just trying to guage interest right now. I will definately put up some pic's when they are done. The machinist begins production on Friday and I should have the parts Mon or Tues. Hopefully I will have the press bent parts by next weekend.
Old 04-05-2005   #6
OK sounds cool. I was planning on getting that JM Fabrications one. But if the one you built can match the quality of his, then I'd be game for one. This still wouldn't be for a couple months though.
Old 04-08-2005   #7
Do you have any pictures of a completed model?
Old 04-08-2005   #8
I didn't put the whole assembly together, but here are some screen shots of a few of the pieces. The runner and then the bottom of the plenum that connects to the runners.
Old 04-08-2005   #9
Looking good. Solid works is cool beans.
Old 04-08-2005   #10
Have you thought about trying any sort of FEA, heat transfer, or fluid dynamics analysis with your design?
Old 04-08-2005   #11
The problem with the flow analysis is that it can't include a lot of the real world things that you see. There is no pulsed flow or air pressure waves. Others have tried doing the flow analysis, but found that it does not hold true on the dyno. Solid Works has that built in, but I don't think it is worth the effort to set it up for it. If it could give good results, I definately would.
Here is one of the cool things that I include on my manifold that noone else has. Coil mounts! The L shaped sets of holes are to mount each coil. The wires will point straight towards the engine. There are also 3 vacuum ports on that end, they have enough room between them to use a 90 elbow, so the lines will be nice and clean. There is also a vacuum port built into the top picture to supply the BOV. It is closer to the BOV up there to make it react faster and keep the engine bay cleaner, because of the shorter hose.
All of the pieces have a milled out edge like this so it all goes together like a jig-saw puzzle. It also allows for a better weld.
Old 04-16-2005   #12
Here are some of the pieces in real life! This is the 2 different throttle body flanges and the base of the plenum that attaches to the runners. The machinist did an awesome job!
Old 04-16-2005   #13
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
correct me if im wrong, but why does it seem like there is an excess amount of chatter? Was he milling too fast? Or did he just kinda get it done because its prototype? Or does it just look that way! ( thats very possible)
- Josh L.P.
Old 04-16-2005   #14
Are you talking about inside the radius? The flash really makes that show up. Looking at the part, it is very smooth. I updated the picture with one that didn't have the flash. The pic is also larger than real life, so remember that.
Old 04-17-2005   #15
Pimpin Dsmstyle
Br0k3N
Dont get me wrong, that looks extremly nice. i know how hard it is to run a CNC and get exactly what you want out of the deal. Most people think its just punching some buttons. its really Lots of math, thought, planning, and specing.
The reason I asked was because i think it was there, and I thought it might effect the way it operates. On the other hand, it may effect nothing.
- Josh L.P.
Old 04-17-2005   #16
You can't even feel any chatter with your finger. It is just the camera making it stand out. These are also the first prototype parts, straight off the mill. All production parts will be polished before they are assembled, so if anything like what you are thinking is present, it will be taken care of. We are making a few changes to the production parts too.
We are also going to add another option on. You will be able to order the runners so they mate up with a stock head, or they can mate up to a gasket match ported head. The stock one will also be able to be ported out at a later date if the head ends up getting ported. It is going to work very slick.
Old 04-30-2005   #17
Raptor
ConArtist
Raptor's Avatar
Flanges look really nice JET!
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 05-01-2005   #18
Thanks Mike! I actually have the whole batch back from the machinist now. I should have some better pic's up within the next few days. I have had a few customer cars come in this week, so they are first priority. Hopefully I can get back on the intake manifold project on Wed.
Old 05-06-2005   #19
Alright, all of the flanges are made and I just received the shoes (outsides of a punch press die) to make the sheet metal parts. I have a 45 ton air operated hydraulic press on the way to form the runners and plenum. I now just need to make the inner part of the punch press dies so that I can bend the runners and plenum. I hope to have this ready to go by next weekend, then it will just be welding them together!
I should hopefully have some done by the end of the month at the latest.
Old 05-06-2005   #20
do you have a picture of the finished product?
